I don;t have much room in my apillar of my BMW only about 25mm deep. Is there anything out there in a ribbon that is that shallow?
#2 |
Does it have to be a flush mounted tweeter? A surface mounted tweeter would look just as nice and opens up a massive array of options.
#3 |
http://www.monacor.com/int/en/produk...pr=EN&typ=full
It is possible to remove the big plastic face plate which leaves you with a small ribbon tweeter that is very shallow. |
#4 |
IMO an automobile interior is the wrong environment for a delicate ribbon tweeter. Remember, even a gust of air can wipe these out! The fidelity difference will not be heard anyhow with all the noise in that environment. If you MUST get a ribbon like tweeter that is more robust, get a planar tweeter. I have some Daytons that I think are just fine (PT-2) and they are considered low end and were cheap enough at about $28 each. Hi-Vi and others make better ones in different sizes. They are not physically as deep mounting factor wise as ribbons.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
| Scanspeak and Ribbon tweet combo | eastcoast | Multi-Way | 4 | 7th March 2008 01:04 PM |
| Ribbon Tweet suggestions.... | eastcoast | Planars & Exotics | 0 | 28th March 2005 07:33 AM |
| Ribbon Tweet mounting Depth | dunderchief | Planars & Exotics | 2 | 27th December 2004 07:39 AM |
| Small amp to drive Ribbon Tweeters | EC8010 | Tubes / Valves | 59 | 6th May 2003 11:44 PM |
| Page generated in 0.07188 seconds (72.30% PHP - 27.70% MySQL) with 10 queries |
