No Voltage on AC 12v line!!
Old 27th March 2007, 11:55 PM   #1
tripathdude is offline tripathdude  United States
Default No Voltage on AC 12v line!!
My ac line was working just fine until Walmart replaced the battery in my car. The constant 12v line is running fine, but there is no voltage on the ac line when the car is either running or not running. I do not know what the deal is. I just replaced the battery so my head unit would work at higher volumes without clipping. Have any suggestions on how to fix this problem?
Old 28th March 2007, 01:31 AM   #2
MadMutt is offline MadMutt  Australia
1 Cars do NOT have a 12v AC Line of any sort.
2 Replacing the battery will NOT give your radio more volume.
Do you maybe mean the accessory line ?
If so then the battery has nothing to do with it.
Check fuses.
Old 28th March 2007, 07:28 AM   #3
I checked the fuses and they seem to all be fine. There is no current on the cigerate line, and the fuse seems to be intact. Any other suggestions?
Old 28th March 2007, 07:37 AM   #4
Most cars will have two or more fuse boxes.
One under the bonnet, one in the cabin.
How are you testing for voltage ?
How did you test the fuses ?
Reason I ask is a freind just called me about the stereo in his wrx not working.
"headunit turns on - but no sound"
Told him to check the fuse under the bonnet (main fuse)
"it looks fine"
It wasn't.....
A clue as to which fuse to look for is to see if anything else in the car isn't working.
If your dash lights fail have look at your park light fuse and so on.
Old 28th March 2007, 08:01 AM   #5
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Re: No Voltage on AC 12v line!!
Originally posted by tripathdude
.............. I just replaced the battery ................
They may have left the accessory connector off when the battery was replaced. Check for loose contact near the battery terminal.
If all else fails, go back to WALMART and complain !!
If it ain't broke, break it !! Then fix it again. It's called DIY !
No Voltage on AC 12v line!!Hide this!Advertise here!
Akai GX 265D line voltage on line outs? ShorBird Solid State 11 27th January 2009 12:44 AM
voltage devider or line attenuator help milen007 Parts 9 24th January 2009 03:13 AM
U.S. Mains(Line Voltage)Connectors OXAUDIO Parts 2 29th January 2008 10:16 AM
Line level subwoofer out voltage? thefish Subwoofers 2 3rd February 2007 08:29 PM
line voltage level metebalci Tubes / Valves 2 1st March 2004 01:45 PM
Copyright ©1999-2017 diyAudio
