Quick question...
Quick question...
Old 27th March 2007, 08:37 PM   #11
WackiCO is offline WackiCO  United States
Ok, is there an easy fix that would decrease the stress that the fan puts on the remote output from the head unit?? The fan is currently moving a LOT of air through the amp, so i dont beleive that slowing this down would have much of an effect...
WackiCO
Old 27th March 2007, 08:38 PM   #12
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Quick question...
Yes you should use the remote wire to turn on a transistor or relay, which then switches your fan power.
Just disconnect the fan for now and see if that makes the amp work again.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 27th March 2007, 09:29 PM   #13
Ohh, I am not thinking that the amp is not working, I replaced that with an amp that works and still am not having any sound go through, the problem i beleive has to lie with either the RCA cable or with the sub....Here is a list of all i have checked
-Head unit - Changed it out w/ working one
-Amp - Changed it out w/ working one
-there is 12v to power port on the amp, as well as the remote port
-there is a voltage coming through the speaker terminals
-I replaced the speaker wire in case something was wrong with that
-checked the connections inside the box to the speaker, everything is ok
Can you think of anything else I should be checking besides the speaker and the RCA Cable??
WackiCO
Old 27th March 2007, 09:39 PM   #14
Did it Himself
Quick question...
I was just wondering if the fan was loading the remote out too much, making the voltage drop. Still enough to drive the fan but not enough to turn on the amp. Long shot but worth a try.
Old 28th March 2007, 03:42 AM   #15
Ok, so i removed the fan from the amp and still nothing worked, However, when i did check the sub terminals for the ohms, it comes up at OL (or doesnt measure anything) when i think that it is supposed to show about 4 ohms....
I am guessing this means my speaker is blown??
I also took a minute and hooked up a speaker I have lying around to the amp and it played...
WackiCO
Old 28th March 2007, 04:11 AM   #16
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
pioneers have small ground planes....after a while the traces become weak then poof!ten you get that zzzzzzzzzz wining sound...only cure is to ground the rca to hu chassis.
sounds like your sub is blown, but check the tinsel leads first, if you can look at the coil through the ventiation holes, you may be able to see if the voice coil has become unwound.
you really should put a relay on the fan, or wire it to a main power wire and put a switch on it.
or get a fan that draws no more than 0.15 amps a 0.34 would be pushing it.
Old 28th March 2007, 02:54 PM   #17
I checked the leads and they appear to be ok, and I'll also work on getting that little wire on the RCA attached to the chassis of the head unit, but where do i attach the other end to?? Do i just put it on ground on the amp or screw it to the chassis of the amp as well??
Thanks very much for your help, I really appreciate it.
WackiCO
Old 28th March 2007, 03:22 PM   #18
Perry Babin is offline Perry Babin  United States
RCA shield grounds on Pioneer head units...
Pioneer intentionally fuses the RCA shield. This prevents a fire hazard if the RCA shield ground contacts the main power wire. This is very common. People pull an amp and leave the uninsulated power wires near the RCA cables in the rear of the vehicle. One touch for a tiny fraction of a second will open the shield.
I've also seen shorted transformers (shorted primary to secondary) cause the shield protection to open.
In the past, they used a thin trace as a fuse. Now they use a real (replaceable) fuse.
When the main power wire shorts to solidly grounded RCA cable, the shield of the cable will burn just like an unfused power wire.
The copper foil/trace is covered with solder mask and can not deteriorate any more than the rest of the traces.
If you ground the RCA shields to the head unit chassis, I strongly recommend that you fuse the jumper wire you use to connect the two grounds.
Old 28th March 2007, 03:41 PM   #19
ahhh very cool, i knew i wasnt the only person that noticed this about pioneers...
WackiCO...you have to solder a wire from the outer ring(shield) of the rca jack to the HU chassis, you can find a suitable screw (usualy the one dead center on the back) and use a ring connector to fasten it....
and put a fuse on it like Perry said (fuse is new to me)
if its not making that wining zzzzzzz sound, you probably dont have to do it....'yet' ....
Old 28th March 2007, 08:05 PM   #20
Will do, and thanks again guys for all your help, I was about to start drop kicking everything in sight when i couldnt figure out what was wrong with this over the weekend....
WackiCO
Quick question...Hide this!Advertise here!
Quick question on the PP-C1 amp athos56 Tubes / Valves 13 20th October 2007 06:37 PM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
Quick PCB question Piper Chip Amps 2 7th March 2005 10:59 AM
VERY quick question... Wyloch Multi-Way 2 3rd March 2005 04:34 PM
