Subwoofer Wiring
Subwoofer Wiring
Old 18th March 2007, 02:08 PM   #1
audiobahnkid592 is offline audiobahnkid592  United States
Default Subwoofer Wiring
Hey does anyone if it is safe to run my two subs at a different impedance off of a mono sub amp? The subs are dual 4 ohms and I want to run one sub at 8 ohms and the other at 2 ohms to yield a 1.6 ohm load at the amp. Will one sub (the 2 ohm) one be getting more power from the amp or no?
Old 18th March 2007, 03:13 PM   #2
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
what kind of amp is it?
Old 18th March 2007, 03:18 PM   #3
Not sure what one I want to use all the time now most likey an audiobahn A18001DT or A18001DQ.
Old 18th March 2007, 03:27 PM   #4
Perry Babin is offline Perry Babin  United States
The 8 ohm woofer would receive 1/4 the power of the 2 ohm woofer.
For example, if the amplifier can produce 45 volts across the speaker terminals, the 2 ohm speaker would receive 1000 watts. The 8 ohm speaker would receive 250 watts.
Old 18th March 2007, 05:48 PM   #5
whats the amp rated at, what ohm? is it a mono or stereo amp?
Subwoofer WiringHide this!Advertise here!
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
Subwoofer Wiring Diagram boris333 Subwoofers 10 4th October 2005 11:16 PM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
