im working on a amp and the ouputs i need are marked a1941 and a c5198 wondering if i might be able to find a replacement of theese two parts they are made by toshiba i have tons of c5200, 2sa1943,2sc5359 wondering if any of the parts i have will work in place of thoose 1941's and 5198's if someone could please help i would greatly appericate it
#2 |
The 5200 is much larger than the originals but if you have enough space for them, they should work.
mcminone has the originals.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#3 |
the 5200 will work for both a1941 and c5198? or just the c5198?
i have alot of 2sc5200's in stock and 2sa1943' |
#4 |
You can't replace a PNP with an NPN. I should have been more clear.
The 2SC5200/2SA1943 pair would replace the original pair.
#5 |
I'm pretty sure that I have the original semis, if you want them. I'll be at the lab on the weekend and I can check for you, if you'd like.
-Pacific
This sure is some swell trash! |
#6 |
ok sorry i cant think today will the c5200 hundred replace the c5198 and the 2sa1943 replace the a1941 is that what u are syaing or no? i cant think im having a bad day sorry
#7 |
Yes, if they will fit into the alloted space.
#8 |
I guess you're not interested. Good luck with the subs!
-Pacific
#9 |
Would you have a schematic or service manual for the reference 650fet r receiver? I have one that is a real neat piece of gear but it has a problem: I get sound out the speakers only if A an B speakers switches are on, and when I up the volume, it has severe distortion untill the protection kicks in. I have new mosfets on order.
Any ideas about this? Thanks! Bob Tatro |
#10 |
Hi, Bob!
You know, I don't think I have EVER come across a 650R, not even while I was fixing audio for Pacific. I will take a look at what I have over the weekend and get back to you. Don't expect much. A lot of the service info for the proprietary Pacific stuff was photocopies, factory notes and institutional knowledge. But I may have it on microfiche. Let me see what I can find out. -Pacific
| Transistor Question | Tripmaster | Chip Amps | 33 | 10th February 2009 09:55 PM |
| Transistor testing question | woody | Solid State | 0 | 10th October 2008 04:08 AM |
| transistor compatibility question | Clipped | Car Audio | 3 | 3rd March 2007 02:29 PM |
| Aleph2 Transistor question! | JarreYuri | Pass Labs | 2 | 26th October 2006 12:29 PM |
| Electrical Transistor question??? | sbisdabomb | Parts | 3 | 7th April 2005 05:51 AM |
