im fixing my friends old audison amp, and am having problems finding the original part for the transistors in the output section.
the originals are STmicro BDW93/94c and i cant find them, the only thing i can find is the STmicro BD911/912 pair. the volt/amp ratings are ok, but the: --------------------------------------------------- hfe @ Ic Vce min/max are totally different. BD= min-15.....max-150.......(A)5...(V)4 BDW=min-750...max-20000...(A)5...(V)3 --------------------------------------------------- Vce(sat)@Ic Ib are also different BD= (V)1 ....(A) 5....(ma)500 BDW=(V)2......(A)5....(ma)20 -------------------------------------------------- will the BD work? what exactly is hfe and Vce? thanx |
#2 |
Hfe is transistor gain and Vce is voltage across emitter and collector. (sat) means saturated or completely on.
#3 |
The originals are darlingtons. The BD911 pair won't work.
If you can't find the originals, the TIP102/107 or the TIP142T/147T pairs should work. The 102/107 has a lower current rating but should work if he's not abusive.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
darlingtons, it should be fun finding those here...
| Transistor Question | Tripmaster | Chip Amps | 33 | 10th February 2009 09:55 PM |
| Could someone please answer this Transistor question | OMNIFEX | Solid State | 12 | 27th January 2009 06:26 PM |
| transistor question | mike49504 | Car Audio | 9 | 10th April 2007 10:59 PM |
| Aleph2 Transistor question! | JarreYuri | Pass Labs | 2 | 26th October 2006 12:29 PM |
| Page generated in 0.08129 seconds (72.01% PHP - 27.99% MySQL) with 10 queries |
