Go Back   Home > Forums > General Interest > Car Audio
Old 28th February 2007, 10:19 PM   #1
Default soundstream 6.0
I am confused on this one , it powers on and off while making a humming noise.
replaced power supply fets and thats as far as I got.
would shorted outputs cause this ?
Ben
Old 1st March 2007, 03:08 AM   #2
If you're using a relatively small 12v power supply (or a battery charger) and there is excessive current draw, the hum may be 60 cycle hum (ripple from the 12v power supply).
With the transistors mounted tightly to the heatsink, measure the voltage across the emitter resistors in the audio section. You should read ~0.00 volts across them. If one resistor (or one group of resistors) reads higher than the rest, that will help you narrow down the channel that's causing the problem.
I'll assume that you checked all of the output transistors to make sure none were shorted. Check all possible combinations (legs 1-2, 1-3, 2-3). On SS amps, you must check every individual output transistor. Also check every emitter resistor to see if any are open.
Old 2nd March 2007, 01:24 AM   #3
where are the emitter resistors
Old 2nd March 2007, 02:07 AM   #4
The emitter resistors are the resistors between the large diodes in the audio section. This amp appears to have 1 ohm resistors in parallel with diodes. It's unlikely that any are open but you can check them anyway.
Check for voltage drop across the emitter resistors (as described above).
Old 5th March 2007, 01:51 AM   #5
I am still new to repairing amps , but do you test the tip 102 and tip 107 the same or do you switch the leads on the dmm.
IF you test them the same way , than I think all 24 outputs are bad.
Ben
Old 5th March 2007, 02:05 AM   #6
The darlingtons are a bit different than regular transistors but you should not read anything near zero ohms between any of the legs of the transistors. While in the board, having only 4 shorted transistors can make it appear that all are shorted.
That amp should use relatively high value emitter resistors (1 ohm I think). so you should be able to pick the shorted transistors out from the rest of the group. Find the ones that have the lowest resistance. The difference may be less than 2 ohms so you'll have to use ohms instead of diode check on your meter.
Old 5th March 2007, 02:43 AM   #7
I am testing them off the board .
When I test them red lead on 1st leg black to 2nd or 3rd should the reading be .5 to .7 on diode check or am I doing it all wrong.
This amp was ran at 1 ohm mono for a few years an got so hot it unsoldered some parts from the board .
Ben
Old 5th March 2007, 10:34 AM   #8
See attached file. Your readings will vary slightly.
Old 7th March 2007, 03:20 AM   #9
I found 6 bad outputs and replaced them , but it still powers on for a few seconds then turns off then on and keeps shutting off.
Ben
Old 7th March 2007, 04:01 AM   #10
Check the drivers transistors on the driver board for the channel where you found defective outputs. If you're uncertain about the readings, compare the resistances from one board to the other.
As you can see, the amp has 4 rows of outputs. If any single output in any row has failed, ALL in the row must be replaced with matching transistors (being from the same batch will generally provide sufficiently matched parts).
soundstream 480.4 wazee Car Audio 3 30th March 2009 09:32 AM
soundstream dbx sub audiobahnkid592 Car Audio 4 6th January 2009 11:59 PM
SoundStream 404 SS64 Car Audio 2 11th October 2008 12:51 AM
soundstream amp help rader Car Audio 4 22nd October 2006 09:18 PM
Copyright ©1999-2013 diyAudio
