Hi, I am making some kick panels + I am going to install 8’’ woofers in my doors. I am thinking about building a time alignment circuit for 3-way active front stage. Does anyone have any reference that I can look at? I have never built anything like that, so I will probably need A LOT of help with this...
#2 |
Did it Himself
Have a look at Linkwitz site, the all-pass network. Probably better just getting a DSP unit though as it's much better done digitally.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
The problem comes down to this:
I will place one extra set of soft tweets on the dash crossed @ 3Khz and I need to delay one, driver's-side tweeter to compensate for 0.5m path difference. If I link 11 of these units together on the tweeter's pre-out line, will it do the job? (0.5m) / (340.29m/s) = 0.001469 s (0.001469s) / (128us) = 11 |
#4 |
If sound quality is a priority, you wouldn't want 11 op-amps in series. Even if you use the best op-amps, it would still be noisy.
Then you have to build a power supply. If the power supply doesn't have a floating secondary, you'd have to build a noise cancelling input circuit. All of this is doable but certainly not trivial. As was suggested, buy something that has this capability.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
Thanks for the advise!
The point is, if you want high-end, just go unbalanced |
| analog circuit for time-alignment? there's Bessel filters and what else? | m8o | Solid State | 54 | 7th February 2007 07:36 PM |
| Page generated in 0.06605 seconds (82.30% PHP - 17.70% MySQL) with 10 queries |
