orion 2250sx amp
orion 2250sx amp
Old 24th January 2007, 11:33 PM   #1
jokerz2 is offline jokerz2  United States
Default orion 2250sx amp
need help! im a complete noobie... i have a orion 2250sx amp that just stopped workin ,, so i opened it up and had one of the fuses popped i replaced it and as soon i turned it on it popped.. so my question is what could be wrong with it... any help would be appreciated thank you...
Old 25th January 2007, 12:13 AM   #2
Perry Babin is offline Perry Babin  United States
If the fuse didn't blow until you applied 12v to the remote terminal, one or more of the output transistors has likely failed.
Do you have a digital multimeter?
Old 25th January 2007, 12:39 AM   #3
troystg is offline troystg  United States
troystg's Avatar
jokerz2- You mentioned "need help! im a complete noobie..." and Perry replied.
Being new you may not realize how much knowledge and experience he has and that if you do precisely as he says, you will have the amp back up and working in no time.
Do a few searches on his name and you will soon find out your lucky to be in such good hands.
Best of luck on it.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 26th January 2007, 07:37 AM   #4
i do have a digital multimeter, how do i go about and check the transistors and on what setting do i put the meter on thank you..
Old 26th January 2007, 07:53 AM   #5
The output transistors are the components clamped to the heatsink adjacent to the large green resistors (likely red/yellow/silver/gold bands).
Set the meter to ohms. Touch one lead to the center terminal and the other the the right-most terminal. If any read near 0 ohms, it's likely defective. If you find 5 that seem to be shorted (zero ohms), it's likely that only one is shorted. You'll probably have to unsolder them to find the defective one. If only one is defective, you can solder the other 4 back in to test the amp for further defects.
Before applying power, you must clamp the transistors tightly to the sink. When applying power, use a 10 amp fuse in the power line.
To remove the clamps, use the procedure shown in the attached image.
Old 26th January 2007, 10:02 PM   #6
jcorkin is offline jcorkin  United States
Not trying to thread jack but i also have a orion 2250 sx, it just burnt a resistor pretty bad, i cant tell what the value of it is, does anybody happen to have the schematics for the amp or have the amp and are willing to open it up and take some pics of the board, i can post a pic of the board if it will help.
orion 2250sx ampHide this!Advertise here!
Orion 2250sx opamps ? Clipped Car Audio 5 19th October 2007 03:15 AM
2250sx - laquer? Clipped Car Audio 5 29th September 2007 05:21 AM
Model of Orion 2250sx Clipped Car Audio 2 13th September 2007 02:59 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
anyone have a orion 2150sx or 2250sx for sale? Clipped Car Audio 1 18th May 2007 01:47 AM
Copyright ©1999-2017 diyAudio
