hi im working on a pioneer amp and it has 2 blown outputs the number is c5100 but when i try to cross it or find replacment it dosent cross wondering if anyone could tell me what i can replace them with? and also working on another amp and had a blown channel the part c 5198 dosent cross either so if someone could tell me what i can use to replace them i would greatly appericate it
As was mentioned, 2S is likely the prefix for this component. MCM has them.
http://www.mcminone.com/search.asp?keyword=2sc5100
When the transistor has a large K on it as the logo, you should also try KT as the prefix. Generally, KTxxxx and 2Sxxxx components are the same but not always. You should look up the datasheets if you're not 100% sure of the part number.
