Amp To Sub Wiring - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 9th January 2007, 04:36 PM   #1
Default Amp To Sub Wiring
I have a Majestic 100W+100W bridgeable amp and would like to wire to a single Punch 3 10" sub (P3D210). How do I wire this? Thanks for the help!!!!
Old 11th January 2007, 01:41 AM   #2
Send a message via MSN to NVMDSTEvil
How many ohms does the amp require when bridged? Is the sub single or dual voice coil and how many ohms per voice coil?
Single voice coil: positive lead to one channel. Negative lead to other channel. Sometimes there will be a graphic on the amp indicating which is the "correct" positive and negative lead to use when bridged.
Old 11th January 2007, 12:34 PM   #3
I have no specs on the amp. The sub is a dual voice coil @ 2 ohm.
Old 12th January 2007, 02:03 AM   #4
Your best option will be to run the voice coils in series most likely.
Run a wire from the positive terminal of one channel of the amp to the positive terminal of one voice coil. Run another from the negative terminal of the first voice coil to the positive of the second. Run a third wire from the negative terminal of the second voice coil to the negative terminal on the second channel of the amp.
You'll have to watch your amp, it may not be stable at 2 ohms (which is what it will be running in bridged mode with two 2 ohm coils in series).
Old 20th January 2007, 04:07 AM   #5
Send a message via MSN to Booradley
I have 2 kicker 10" DVC subs that are 4ohms each. I have a fosgate power 1000bd mono amp that is 500wx1 @ 4ohms.
When the subs are wired in series will this work?
Old 21st January 2007, 02:33 AM   #6
Each sub will have to be wired up as an 8 ohm load (two coils in series). This will net you 4 ohms at the amp. Should work good.
Wiring HT2 MTM ZoZat Multi-Way 4 15th May 2009 09:17 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
Copyright 1999-2017 diyAudio
