power acoustic amp
power acoustic amp
Old 5th January 2007, 12:59 PM   #1
mike49504 is offline mike49504  United States
Default power acoustic amp
im working on a power acoustic amp the left channel plays fine the right channel will play 5 to 10 sec's and go dead for 10 to 20 secs then play again for another 5 10 secs and shut off i checked all transistors in power supply and all the outputs all check fine wondering what i check from this point
Old 5th January 2007, 04:47 PM   #2
Perry Babin is offline Perry Babin  United States
What model amp?
Is the timing consistent (like a mute/delay circuit being engaged repeatedly) or is it random?
Is the fault in any way affected by vibration or by applying pressure to the board?
Does it use two independent power supplies supplies (not likely on a PA amp)? If so, is one supply shutting off?
power acoustic ampHide this!Advertise here!
power acoustic 620-2 scampo77 Car Audio 4 23rd June 2009 01:35 AM
Acoustic 160 adjustments llwhtt Solid State 0 28th April 2009 11:55 PM
need help on a power acoustic lt1920-2 amp truckr012001 Car Audio 5 30th October 2008 10:58 PM
Acoustic Reasearch have' Solid State 3 20th August 2005 10:19 AM
Acoustic pre-amp james27_84 Instruments and Amps 4 23rd March 2005 06:49 PM
