I'm looking for an A/B switch rated above 100 amps that I can use to power a composite speaker cabinet without playing the in car speakes. They make tons of these for home entertainment systems but I can't find one compatible for a 125 wattper channel car amp. Crutchfield said they know of nothing, but there has to be some way to seperate the two sets of speakers.
#2 |
Why wouldn't a toggle switch work to break the connection to the in-car speakers?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I thought of that but I can't find a 12V toggle rated over 40 watts. If anyone knows who might sell one it would be greatly appreciated.
#4 |
Switches are typically rated in current, not in watts. Any switch rated for 6 amps or more will work.
A switch rated for 5 amps of current would likely work fine but 5 amps of current into 4 ohms is only 100 watts. Since the audio signal isn't constantly going to drive 5+ amps into the speaker, a good quality 5 amp switch should hold. If, for some reason, you want to use a particular switch with lower current ratings, use it to control a couple of Bosch type relays. They will easily handle the load.
#5 |
Try this page it might be helpful.
http://www.the12volt.com/relays/page5.asp |
| Low tech speaker switch needed | clippo | Multi-Way | 4 | 30th April 2009 02:43 AM |
| altering a speaker selection switch | ronpilgrim | Parts | 1 | 29th April 2009 03:58 PM |
| Speaker switch | smithy666 | Solid State | 12 | 8th August 2008 08:02 PM |
| SI Super-T and speaker AB switch to ONE speaker | Taperwood | Class D | 25 | 24th March 2006 02:08 AM |
| speaker selector switch | blbarth | Multi-Way | 4 | 22nd January 2006 01:07 AM |
| Page generated in 0.08015 seconds (74.79% PHP - 25.21% MySQL) with 10 queries |
