would half box volume work? - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 2nd January 2007, 08:41 AM   #1
Hayden is offline Hayden  Australia
Default would half box volume work?
I would like a smaller box I know the recommend volume is best but if I half the box volume on any sub wouldnít that double the resonate frequency?
I havenít a clue in this area so how does that work?
Some specs of the sub.
Qts: .234
Vas: 185.60
Fs: 21.40
Re: 2.050
Le: 3.25
Z: 4.00 ohm
Qms: 8.838
Qes: .240
Spl: 90.83
Bl: 31.41774
Dd: 42.62cm
Sd: 1426.0 cm2
Old 2nd January 2007, 10:47 AM   #2
pinkmouse's Avatar
Download one of the many box modelling programs and have a play.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 2nd January 2007, 01:28 PM   #3
I have winISD pro would that work?
I found this one http://www.geocities.com/f4ier/newsubsim.htm
How accurate is this? Or do you recommend a specific one?
Old 2nd January 2007, 02:38 PM   #4
pinkmouse's Avatar
WinISD is fine, I prefer Unibox, but it's a little more complicated.
Old 4th January 2007, 02:15 AM   #5
Thanks for the info, Iíll do more research by reading and software and see what I come up with.
Old 21st January 2007, 10:59 AM   #6
Hi hate to say this but I donít know much about the real technical terms of speakers but I loaded a soloX 18Ē into winISD PRO and set the sealed box at 2cuf it loses 3db around 10-20hz I have no idea but will this effect the sound that much?
To me I donít understand the program because you add mass to the cone and you get a db rise over the frequency response doesnít make sense to me.
I have limited space I canít go much bigger than about 3cuf sealed or ported box
Will I lose much power?
The sub requires a 6 cu.ft. sealed and 5 cu.ft. ported
Any help will be greatly appreciated
How does this volume control work? Stuey Everything Else 7 15th November 2006 01:11 PM
possible volume and balance control - does this look like it will work well? photo_marc Tubes / Valves 2 25th January 2006 10:46 PM
Clipping? why not build amp with twice rms needed and only use half volume? John Biles Everything Else 22 29th September 2005 06:12 AM
Would this work as a volume control??? george a Solid State 6 17th December 2004 02:43 AM
Low cost PWM volume control. Could it work? punkomat Solid State 6 2nd July 2004 09:56 AM
Copyright ©1999-2017 diyAudio
