Rockford FETS  MT75N05
Old 30th December 2006, 04:53 PM   #1
Tom7227 is offline Tom7227  United States
Tom7227's Avatar
Rockford FETS  MT75N05 Send a message via AIM to Tom7227
Default Rockford FETS MT75N05
Hello fellow technicians,
I am so glad I found this forum to share car audio amplifier repairs.
I am looking for a replacement FET for the MTP 75N06 FET used in this Rockford Amp.
Finding the Holy Grail seems easier than finding the exact FET, I know there is a substitute and a replacement SMT gate resistor, but locating were the info is ...challenging to say the least.
And info would certainly be very helpful.
Tom
Old 30th December 2006, 05:45 PM   #2
1moreamp is offline 1moreamp  United States
You can use almost ANY 75 amp rated FET. May I suggest IRF-2807 or IRF-1010. The 60 volt rating can also be as high as 100 volts without issue.
I use 75339P By Intersil, or 75645P by Intersil Fairchild.
The IRF numbers are slightly higher current rated, which does not hurt withing reason. I also use IRF-3205 for heavy duty replacement, but you might have to lower the gate resistor value abit to get proper gate operation.
Just about everybody makes a general purpose 75 amp rated FET. I would only be worried about the the ON resistence of the two different FETs, as this does affect the total on power for the power supply.
Good Luck and pls use http://www.findchips.com/avail for your part search.
Old 30th December 2006, 07:50 PM   #3
Perry Babin is offline Perry Babin  United States
I'd use the IRF3205s. If the gate resistors are 51 ohms or less, they are OK. 68 ohm resistors are borderline. 100 ohm resistors won't work.
The symptom for too much gate resistance is excessive current draw at full duty cycle. Generally, you'd run your bench power supply near 13 volts. This will cause the duty cycle to be cut back because the supply can easily hold its target power supply voltage with 13v input. When you turn the voltage down below 11 volts, the duty cycle will increase. You want to turn it down untill the duty cycle no longer increases. If the current draw is more at the low voltage, you need to decrease the value of the gate resistors.
Of course, this assumes that the driver transistors are intact. The transistors labeled 2A typically fail. On occasion, the 1A transistors will fail. The TLx94 IC in most Rockford amps will operate with no B+ voltage (only ground and remote connected). With the new FETs in place, you can look at the gate waveforms to see that they're turning off quickly (sharp vertical fall on the right side of the waveform).
Old 31st December 2006, 07:02 PM   #4
Tom7227's Avatar
Thanks for the replys,
I will try the 3205's, cause I have alot of those.
Tom
Old 1st January 2007, 06:53 AM   #5
Tom
They will work fine. Hope your good at working with MESHA. I do about 10 or 12 a week currently.
Happy New Year !
Rockford FETS  MT75N05Hide this!Advertise here!
rOCKFORD P8002 edfirebird68 Car Audio 18 6th January 2016 03:39 AM
Rockford vs JBL vs Soundstream zafira1981 Subwoofers 17 8th June 2009 02:04 PM
Mysterious Rockford amp DigitalJunkie Car Audio 1 5th November 2007 11:37 PM
Rockford Punch 75 (non HD) Clipped Car Audio 8 18th October 2007 10:56 AM
a few words on 1.4kw rockford amp mikee12345 Car Audio 9 15th October 2003 08:51 AM
