where to get replacement terminal screws for car amps? where to get replacement terminal screws for car amps? - diyAudio
Old 29th December 2006, 04:34 AM   #1
spooney is offline spooney  United States
Default where to get replacement terminal screws for car amps?
I have a couple amps that are missing a few terminal screws.does anybody know a good place to find some replacements?
Old 29th December 2006, 07:30 AM   #2
Perry Babin is offline Perry Babin  United States
If you want the screws with the plate washer, try ebay (search for amp screws) or http://www.amplifierscrews.com/index.htm.
The metric screw section of any hardware store should have screws that fit. You'll have to use a spade or ring terminal.
Old 31st December 2006, 02:16 AM   #3
:xrow: is offline :xrow:  United States
If you're talking about the set terminals that you tighten on to the wire, here is a link to a place that sells them. I can't link straight to them so you'll have to scroll down to the section called Fastening and Sealing. Under that section, click on Set Screws.
http://www.mcmaster.com/
Old 31st March 2008, 06:37 AM   #4
Amp Screws is offline Amp Screws  United States
Default Where to buy car amplifier screws
http://www.AmplifierScrews.com
Old 31st March 2008, 02:06 PM   #5
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
Also look for Grub screws - My RF amp uses M4 ones FWIW.
where to get replacement terminal screws for car amps?Hide this!Advertise here!
3 terminal regulator with 3 terminal shunt reference BWRX Power Supplies 11 17th January 2013 09:08 AM
PSU capacitor replacement for Marantz MA-500 mono amps SimontY Solid State 6 6th May 2008 08:19 PM
Rockford Fosgate Terminal Screws spooney Car Audio 1 20th October 2007 05:29 PM
Replacement for screws? GeniX Multi-Way 7 20th October 2003 09:24 AM
Copyright ©1999-2017 diyAudio
