Loosing my BASS somewhere! - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 18th December 2006, 02:51 PM   #1
NickUK is offline NickUK  United Kingdom
Default Loosing my BASS somewhere!
Hi. Installed so MUTANT 60watt RMS 2way component speakers in my MK4 VW Golf at the weekend. The problem i have is that i seem to be loosing all my bass in the door! It sounds ok but when i turn up the music the speakers get distorted and i have to turn the BASS down! The speakers are pumping the bass but i cant here it! I believe its becasue the speakers arn't up to the edge of the door panel and the sounds being lost! Is there some sort of collar i can buy to go around the speakers housing so i can pus this up tight to the edge od the door lining? Otherwise i'll have to make my own! Any advice is good.
Old 18th December 2006, 07:44 PM   #2
Stocker is offline Stocker  United States
small speakers with limited-travel suspensions are for mids and highs. To produce loud bass, you need lots of cone area and travel. Even a poor subwoofer is better than none and will easily be bought and installed if you do the work yourself for <$100.
Jesus loves you.
Old 18th December 2006, 07:57 PM   #3
stoN_Cold's Avatar
Default Hi !
If macanicaly is all ok, check polarity of wired loudspeakers. Maybe you reversed !
Regards zeoN_Rider
Old 3rd January 2007, 01:29 AM   #4
It sounds like Nick is saying that there's a gap around where the speaker is. If air is allowed to move out from the sides of the speaker, the waves from the back of the speaker will interfere and cancel out the front waves, or so I've read. I've never had the problem myself, but have always ensured that there is no gap around the speaker.
If you don't have enough clearance to sink the speaker in all the way, then yeah, it sounds like a spacer might help. Worth a try, anyway. Good luck!
KT66 loosing its getter ixe13 Tubes / Valves 2 27th February 2008 01:33 AM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 09:18 AM
Copyright 1999-2017 diyAudio
