Old School Orion 2150 gx.I must repair this amp - Page 9 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Closed Thread
Old 6th February 2007, 09:48 AM   #81
You can rent a scope in some areas but it's likely to be expensive.
It would be nice to confirm that the signal is good up to the op-amp but that's going to be difficult without a scope.
Since the outputs failed, you can assume that the problem is beyond the op-amp.
These are simple amplifiers so troubleshooting the audio section isn't usually difficult or time consuming. The power amplifier section of the amp begins with the op-amp nearest the outputs. The output of the op-amp goes to the 4 diodes connected in series.
The drive signal goes from the diodes to two small transistors (MPSA06/56 or MPSU07/57). For clarity, let's call them pre-drivers. These transistors typically have their emitter connected to shield/secondary ground via a low value resistor (less than 300 ohms). The collector is connected to the base of another small transistor. Let's call these the drivers.
The collector of the drivers is connected to the collector of the output transistors which is also the output of the amplifier. The emitter of the driver is conected to the base of the output transistors via a low value resistor.
The signal path is roughly ... op-amp >> 2.7 ohm resistor >> diodes >> predrivers >> drivers >> output transistors >> speaker leads.
I'm not sure if this will work but you can try it. To troubleshoot a grossly distorted signal (1/2 of the waveform completely missing), you need to determine which half is missing. Since you don't have a scope, try this. Connect a load to the amplifier's speaker terminals of the defective channel. Since it plays, I'll assume that there is no DC on the speaker leads. Touch the black lead of you meter (set to DC volts) to the shield ground of the RCA jacks. drive a signal into the amp. Does the meter read a positive or negative voltage. If the voltage is positive, you would assume that the negative half of the waveform is not being produced and you would investigate the circuit driving the negative half of the waveform. This would be a PNP transistor (connected to the diodes) then the NPN transistor (connected to the base of the outputs) and then the outputs. If the voltage goes negative when the signal is driven into the amp, you'd investigate the half of the channel responsible for producing the positive half of the waveform.
The low value resistors often fail and you should check all of them in the defective channel.
Old 7th February 2007, 03:54 PM   #82
dB-r is offline dB-r  United States
Did the other channel (that was working fine before you replaced that cap) only start having this distortion with that cap replaced? Take it back out and see. You may have a little solder bridge somewhere near that capacitor causing the distortion.
If you get your hands on a scope you can trace the input signal from the RCA connectors on back into the circuit board to the opamps and try to find where the signal starts getting distorted.
BTW: What is the low impedance rating of a HCCA 250r model? I believe it is .5 ohms, but not for sure. It's big, long and red in color. Not the 250HCCA model, but the 250R HCCA model (newer, but not newest series of Orion, probably second generation).
Old 7th February 2007, 09:58 PM   #83
spooney is offline spooney  United States
One channel worked fine and one channel didn't play hardly at all.I replaced both caps at the rca inputs and the channel that worked fine before still did.The channel that was very low now has solid volume.Its just distorted.So nothing got worse with the addition of the new cap.I'm one step closer to getting this hog working I just need to get my hands on an O-scope and trace down the source of distortion.
Old 26th February 2007, 01:42 PM   #84
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I was looking for a 225HCCA thread but didn't find any......this might do.
I have a blown 225HCCA amp with all ten IRFZ44 fets blown (shorted gate to drain) and the output devices seem to be ok.
the silpad has already fallen apart because of old age....I was thinking of mounting the transistors directly on the heatsink with grease since the heatsink is anodized but probably will get some mica insulators.
now, the problem.... the resistor that connects both totem pole drivers to ground (from MPSA56 collector to ground) is burned. I need the value for those resistors.
thanks for any help!
Old 27th September 2007, 01:57 AM   #85
i just hooked this amp up again for the first time in a long time and although that one channel is distorted it isn't as distorted as I originally made it out to be.Actually it sounds like the distortion mainly falls into the bass range.Would this indicate a particular component or components that cause this type of distortion?
Old 27th September 2007, 02:23 AM   #86
It sounds like one half of the output is clipped or not being produced at all. Do you have a scope?
Old 27th September 2007, 04:03 AM   #87
no i don't . Thats why this amp has sat for as long as it has.I was hoping maybe the fact that the bass was distorted might tell what specific component was causing the problem.I'll just have to sit on it until i get access to a scope.
Old 27th September 2007, 04:09 AM   #88
If you have a sine wave generator that will go down to 5hz or so, you may be able to tell if the amp is producing both halves of the waveform. The frequency response of the amp will be down at that frequency but the amp should still produce enough of it for you to tell if it's moving the speaker equally in and out from the point of rest.
Old 20th October 2007, 07:13 PM   #89
Picked up this old dog today and played around with it.I had purchased some caps a while back to use in it and I was bored so I replaced those ( 3- 10 microfarad 35 volt caps,2- 3300 microfarad 16 volts caps,and 2- 470 microfarad 25 volt caps) as well as touched up some spotty looking solder points.For the hell of it I figured I'd try moving the transistors in the output section onto a different solder pad to see if it made a difference in the output. I'm not really sure what I did but today was the first time i've ever heard this amp play cleanly from both channels. The 10 microfarad caps were in the output section the 470's were right next to the rail caps and the 3300s were power input caps.If it was the movement of the transistors in the outputs that solved the problem would this indicate that the resistors connected to the transistor were bad or out of tolerance?
Old 25th October 2007, 01:20 AM   #90
when i start putting this thing back together would it be beneficial to use heatsink compound between the transistors and the insulating tape?
Closed Thread
Help with Orion 2150 Gx v-dub-guy Car Audio 7 20th January 2008 03:25 AM
PPI 2150 AM Dead! Need help or good repair person! PyroZona Car Audio 69 5th December 2007 09:39 PM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 02:55 PM
orion xtr 2150 mike49504 Car Audio 11 1st October 2006 01:19 AM
couple old school orion questions Clipped Car Audio 3 5th August 2006 11:09 PM
Copyright 1999-2017 diyAudio
