I have a hifonics that had the protection light on. I Fixed this problem, Now when the protection light goes off the amp doesn't turn on. Here's my quick question, it uses the Ka7500bd smps controller can i use a tl494 as a replacement. The amp is a zx7500.
#2 |
I think the 7500 is the same as the TLx94 but I'd suggest using the 594 instead of the 494. The 594 has always been a good replacement for the 494 but the 494 was not always a good replacement for the 594. I don't think this is a problem in the newer amp designs but it was in some of the older designs so I always use the 594 because I know it's not going to cause any unforeseen problems.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I finally changed the pwm chip, thinking this is my problem, I ordered 594's but first i wanted to see if it worked with the 494. It works, but I'm not having nice square waves on the inputs, and pin 9 and 10 are only 1.8v. I find that a little low, I'm guessing 5v is the norm on this amp. Also the outputs have 21volts on one side and only 17volts on the other. Then i put in the 594 to see maybe the chip is not strong enough to run 4 drive transistors, the 594 is even worse i get only 17 and 11 volts on the outputs and the light is barely on.
p.s. I learned with the original chip the ka7600bd, the supply would start up then shut down. Here are voltages on the chip p1 :1.2mv p2 :5v p3 :62mv p4 :186mv p5 :1.71v p6 :3.94v p7 :gnd 0v p8 :11.28v p.s. p9 :1.789v p10 :1.799v p11 :11.28v p12 :10.64v p13-14-15 :5v p15:.872v |
#4 |
This is very strange. With only 186mv of deadtime, you should be very near full duty cycle.
I breadboarded a chip and set the deadtime to ~190mv and the output was ~4.5v. Have you measured a square wave gate drive before with that meter? Do you know if it will read ~1/2 B+ with a 50% duty cycle square wave?
#5 |
#6 |
If that's 5us/div, the operating frequency is too high. The timing capacitor is likely the cause but you should also check the timing resistor.
Ct and Rt are connected to pins 5 and 6 of the 594.
| Sub for Gen VII HiFonics | Morts | Car Audio | 0 | 26th May 2009 04:29 PM |
| Hifonics BX1000D | Dobermann | Car Audio | 2 | 26th September 2008 04:27 PM |
| Hifonics Boltar VIII Problem | vypr | Car Audio | 22 | 19th February 2008 03:46 AM |
| Hifonics Zeus VII | redimp | Car Audio | 1 | 20th December 2006 10:47 PM |
| Hifonics pluto amp | deriver23 | Car Audio | 1 | 27th September 2006 06:09 AM |
| Page generated in 0.07450 seconds (78.83% PHP - 21.17% MySQL) with 10 queries |
