Farnell?
Something in here?http://nl.farnell.com/jsp/search2/b...search_001&Ntt=dil4060&Ntx=&_requestid=293541
If it's the type of class D section that uses that IC as the integrator's square wave source, check pin 5. It should have an 80kHz square wave on it. If you have that signal on pin 5, the IC is OK. I've never seen one fail.
The MC14060BCP should be the same IC. Confirm before ordering.
