I plan to build SMPS based on SG2325 and intend to use 8 IRFZ44 (4 per rail). Do I have to match voltage Gate-Source of thease mosfets for proper current sharing?
#2 | |
Good question. I have not seen much work in that area. You can gain match if you like. I have seen Rockford Fosgate amps use 1 FET per conductor on there primary. This sort of bypass's the issue of gain matching the FETs for current sharing, as each FET has its own single load to operate into. PG does this also on there MS-2250 and MS-1000 (a dual 2250). I have not seen much else ever done concerning the gain differences in each FET. I believe this is mostly due to the fact that nonlinearity in not a real issue in a single frequency variable pulse width operated load. I know that I have seen very little matching effort in power supplies. Of course car amps are built pretty cheap nowadays |
#3 |
It should be SG3525 and not SG2325. Sorry for that.
#4 |
What is probably more important than gain matching is RDSon matching. Differences in RDSon may lead to core saturation.
space |
#5 |
Thanks for all comments. After searching for MosFets I have found IRFP2907( Id=209A, RDSon=4.5mOHM, Pd=470W),TO-247 package, which is very interesting. Can I use just 2 of this, only 1 per rail, to make sure that no current variation in each smaller MosFets. Poweramp section would be 4 channels of LM3886.
#6 | |
Try replacing your Z-44 fets with IRFZ-48's they will lend higher reliability at no extra cost in circuitry change. Your trying to build a very precise power supply for a rather rudamentry amplifier. I would go with the Z-48's and live with the improvement that generates they are rated at about 20 amps more power each, and in a array of 4 thats an extra 80 amps of switch headroom. your still dealing with the original toroid coil spec's so there is where your limited. Not the Fets...
| Series MOSFET regulator better with just voltage ref on gate or with error amp? | ray_moth | Tubes / Valves | 69 | 20th May 2011 01:35 AM |
| mosfet gate voltage question | carpenter | Pass Labs | 6 | 22nd July 2009 02:34 AM |
| Gate-source voltage needed to switch a FET | rtarbell | Power Supplies | 9 | 9th January 2007 10:27 AM |
| MOSFET gate voltage | xplod1236 | Parts | 17 | 4th December 2004 03:23 PM |
| Where to buy a low gate voltage p channel MOSFET or make an alternative? | Corn-Picker | Everything Else | 6 | 16th December 2003 10:15 PM |
| Page generated in 0.09393 seconds (76.70% PHP - 23.30% MySQL) with 10 queries |
