Need help with voltage regulator - HU problem
Old 14th November 2006, 07:41 PM   #1
valterdaw is offline valterdaw  United States
Default Need help with voltage regulator - HU problem
My latest headunit is very sensitive to a voltage. On a cold start, my car produces around ~16v then in 20-30min it slowly drops to normal, which indicates voltage regulator problem (built-in in Bosch alternator). During this period of time headunit just shuts down it's display and disables all controls except volume and track change (Eclipse). I would rather avoid alternator replacement (lost receipt ), so I am looking at simple schematic of voltage regulator, which will be feeding just headunit. It doesn't need to be powerful, as I am using only pre-amp outputs from HU. I appreciate any help!
Old 15th November 2006, 01:02 AM   #2
ocaukrell is offline ocaukrell  Australia
Just politely, fix/replace the alternator.
Items that can be fried by high voltage.
Battery
headunit
amplifiers
ECU,s
bulbs
fuel pumps
fans
electric motors
So if you car is a later model that has fuel injection/elec windows etc.
You are asking for a world hurt.
Maybe not right now, but it will come back to bite you.
Last car I saw with a dead regulator needed, alternator, battery, car phone, ecu, gearbox controller.
End bill was around $5,000.
Your choice..............
Old 15th November 2006, 01:59 AM   #3
Thanks! I am even not sure alternator (with regulator) will fix it, OEM and Bosch doing the same thing to my friend's simular cars. It's been like that for almost 5 years, it just went a bit higher lately with cold weather and battery replacement (optima, sealed). I might give it a try, pick up a different alt., which will be a good excuse to upgrade for bigger one
Old 15th November 2006, 02:19 AM   #4
Thats interesting.
I know the occasional system will generate/require high 14's, but 16, I'm thinking there has to be a fault.
Most alt will only put out 16 at maximum with reg failure.
What sort of car is it ??
Old 15th November 2006, 04:10 AM   #5
Jexx is offline Jexx  United States
Send a message via MSN to Jexx
Stock alts are cheap, $150 max. Easy to uninstall/install for american cars...might want to check a junkyard.
Need help with voltage regulator - HU problemHide this!Advertise here!
problem with dual +/-15V voltage regulator sunrise Pass Labs 2 23rd June 2006 06:17 PM
VOltage regulator works, but theres a problem silentblackhat Solid State 8 15th June 2006 09:36 PM
IC Voltage regulator (LT1083) problem trombone Power Supplies 5 10th March 2006 02:28 PM
Voltage Regulator Problem? fmak Solid State 43 16th April 2002 11:24 PM
What voltage regulator to use? Thomas Everything Else 2 28th September 2001 02:53 PM
Copyright ©1999-2017 diyAudio
