I blew my amp last week. (short circuit on the output speaker I see that the four 75339P were smoke. I changed all four with IRF3205 and now the amp doesn't want to turn on. Did someone have an idea if I have something else blew? Thanks, |
#2 |
Post a list of the DC voltage on each of the 16 pins of the TL494.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#3 |
Here's the DC voltage of the TL494
PIN #1 : 0 PIN #2 : 0 PIN #3 : 0.06v PIN #4 : 1.15v PIN #5 : 0 PIN #6 : 0 PIN #7 : 0 PIN #8 : 11.5v PIN #9 : 0 PIN #10 : 0 PIN #11 : 11.5v PIN #12 : 11.6v PIN #13 : 5v PIN #14 : 5v PIN #15 : 5v PIN #16 : 0 The LED that show the power on wasn't on!
#4 |
The IC has input power on the right pins but 5 and 6 should not be near 0v. Pin 6 should be ~3.7v and pin 5 should be ~1.5v. If those are accurate readings and nothing is shorting those pins to ground, the IC looks like it's damaged. In most cases, when the IC is damaged the 5v reg is off but yours is dead on.
With no power appled to the amp, set your meter to ohms and measure the resistance between pins 7 and 6 and then between 7 and 5.
#5 |
Between the pins 7 and 6 is 1.8 kohm
And between pins 7 and 5 there is infinite.
#6 |
I think the IC has failed.
| MTX 6500D - No Output | Pioneer621 | Car Audio | 112 | 16th February 2012 03:16 AM |
| MTX 6500d Parts | weston_sagle | Car Audio | 19 | 21st September 2010 08:44 PM |
| MTX Thunder 6500D burnt | ifrythings | Car Audio | 10 | 18th April 2008 05:35 AM |
| MTX 6500D repair | bil | Car Audio | 3 | 29th May 2006 06:19 AM |
| Thunder and lightning. In | jleaman | Everything Else | 3 | 8th July 2003 07:12 AM |
