My 15 year old son has purchased two 10" Subwoofers, for installing into his 1994 Thunderbird with the following spec. power -1000 watts max voice coil= 2" znom= 4 ohms Fs= 26.9 Hz SPL= 83.5 dB 2.83v/1m Vas= 2.39 cu ft. Qms= 5.23 Qes= .89 Qts= .76 Dual voice coil Diminsions: A= 10.16", B= 9.69", C= 6.8" My question is can someone with more knowledge than I help direct us to a proper box design,for this application, as oppose to him just buying whatever box has clear covers with neon lights. Thanks for the help |
#2 |
Did it Himself
They will need to be in a sealed box of at least 2 cu ft each. Unfortunately Qts is very high, makeing the box big but at least it will go a little deeper. As Qts is so high there will always be some peaking in response. They are not suited to a vented box.
The real power rating of them is probably more like 250 watts RMS.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
What kind of speakers are they?
Those would work in IB. How big is the rear deck on that t-bird? |
#4 |
I've tried modeling them with winisd pro (with cabin gain) and all i can say is throw them out, yuch.
they are just revolting, nothing I do seems to make them look any good, to get anything close your looking at a sealed 50ltr MINIMUM each. Good for loose sloppy boom and even thats being generous. Sorry but your son has just wasted $10........ |
#5 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
After some number crunching my calculator has given some way out of reason numbers....These drivers seem to have been engineered out of range of what would be considered "High-fidelity"...as a result I cannot seem to get any rational numbers for it.
Reverting to rule-of-thumb I'd say one large box of one inch thick medium density pressboard....48 inches long, eighteen inches deep, twelve inches high. Divide in half with a partition, two inch long screws every five and a half inches with a good wood glue, stuff it with a cotton batting (Easily found at a fabric store). Find a car stereo place to put this "box carpet" over it...find some 10 inch "industrial" grills, a terminal box (Four total)....drop the drivers in it somewhat off-center onto the completed box, wire it up & your done! ___________________________________Rick........... |
#6 |
what if i where to butt these up against each other in the push pull type configuration, does this make the enclosure much smaller.
also the deck of the tbird is large enough to hold these without an enclosure, is that best suited for these last www.pyleaudio.com show these in almost normal size boxes, these items are huge and heavy, its hard to believe they are so off. is any of these they show worth while to copy?? Series Blue Label Model PLBN102 Brand Pyle Category Subwoofer Enclosures MSRP $210.90 Warranty 1 Year Item Manual PLBN102 Click Here -------------------------------------------------------------------------------- PRODUCT INFO Detail Two 10'' High Power 4 Ohm Subwoofers Silver Polypropylene Cone Specially Treated Black Rubber Edge Suspension 2'' Aluminum Voice Coil Bandpass Alignment for Extra Deep Bass Plexi Glass Front Window Blue LED Woofer Rings 4 Tuned Ports 1000 Watts Max Power Handling Dimensions: 30''W x 13.6''H x 14.8''D Dual 10'' 1000 Watt Bandpass System w/Neon Woofer Silhouette Series Blue Wave Model PLBWS210 Brand Pyle Category Subwoofer Enclosures MSRP $195.70 Warranty 1 Year Item Manual PLBWS210 Click Here -------------------------------------------------------------------------------- PRODUCT INFO Detail Two 10'' High Power 4 Ohm Subwoofers Blue Neon Silhouette Woofer Rings Silver Polypropylene Cones Specially Treated Rubber Egde Suspension 2''Aluminum Voice Coil Bandpass Alignment for Extra Deep Bass Quick Connect Input Terminals Plexiglass Front Window 1000 Watts Max Power Handling 2 Tuned Ports Frequency Response: 35Hz-1k Hz Dimensions: 13''H x 25.5''W x 14''D Is throwing them out the only answer?? |
#7 |
Isobarik will help yes.
Were not saying they wont go boom boom, just that from a point of being 'enjoyable musical bass' they will be lacking. Dont spose you can measure the theil/small rather than rely on the crud they supply ?? Might put them in a different light. Will be a good learning experience for your son. |
#8 | |
So it's this one?: http://www.partsexpress.com/pe/showd...number=292-135 Maybe they accidentally tested it with only one voice coil hooked up? |
#9 |
i will look into actually measuring these, give me a few days and i will get back to all
and thanks for all the assistance so far. by the way Is this company known for providing less than good speakers as well?? |
#10 |
Yes lothar34 that is exactly the woofer he bought.
I have emailed both pyle and parts-express, just in case the spec has a typo , but i will try and measure it. thanks again for all the help here |
| Needed assistance to build speaker box. | bentley388 | Full Range | 4 | 4th August 2007 02:57 AM |
| Assistance needed with an FE-166 look-alike | renfrow | Full Range | 1 | 14th August 2006 05:42 AM |
| 2-Way Driver Selection Assistance Needed | mevaniuck | Multi-Way | 4 | 29th April 2006 02:36 PM |
| Assistance needed for VU meter transplant | Nordic | Parts | 1 | 5th November 2005 06:37 PM |
| Design modification assistance needed | googler | Multi-Way | 11 | 20th August 2005 11:25 AM |
| Page generated in 0.11287 seconds (81.49% PHP - 18.51% MySQL) with 10 queries |
