Simple 12v mono power amp for bass driver - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 1st November 2006, 11:39 AM   #1
dhole is offline dhole  United Kingdom
dhole's Avatar
Default Simple 12v mono power amp for bass driver
Ello all
Im looking to build a mono power amp to power a subwoofer for my car .This being a diy forum there seems to be very little in the way of such things. Can anyone advise on an amp ? circuits etc ? Would have thought there would be.
cheers
dave
The luminous space in the Sword of Orion...
Old 1st November 2006, 11:45 AM   #2
Did it Himself
richie00boy's Avatar
You need a switched mode power supply to get the necessary voltage rails, then any normal typical amp that can run 4 ohms will do.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 1st November 2006, 03:46 PM   #3
diyAudio Member RIP
generally car audio fans are not keen on complexity and
expensive building costs just for the sake of DIY.
Car amplifiers are complex due to the power supplies for high power.
A simple bridged circuit maxes out at 20W into 4 ohms, after that
you need switched supplies.
Take something like this :
http://www.maplin.co.uk/Module.aspx?...FIERS&doy=1m11
The casework would cost you near 40 before you've even started.
or this :
http://www.motor-world.co.uk/kroozin...p?prod_id=2174
25 !
/sreten.
Old 7th November 2006, 08:29 AM   #4
dangus is offline dangus  Canada
If you could score a broken car amp that still has a good power supply section, you could build your own power amp stage for it.
Or, you might come across an amp that just needs some basic repair like a busted volume control pot. (Like the 230 watt RMS mono Kenwood that I got at a flea market)
Old 13th November 2006, 02:27 AM   #5
There's one right here:
http://sound.westhost.com/project89.htm
That's a supply; then, just hook up whichever amp you want. It's a tricky supply, though; better would be a microcontroller-based PWM supply using an H-bridge FET configuration... if you can get the output filters right.
I built that project 89 supply, though I haven't put much of a load on it to test it out. It's a little uneven from rail to rail, which makes me worry I wound the tranny with an extra coil on one rail. It is doable, though.
How to build a simple balanced mono line mixer jandalo Analog Line Level 4 8th November 2008 12:40 PM
ELK bass amp, mono, twin OPT's (?) Empee Tubes / Valves 0 26th March 2008 02:39 PM
simple stereo RCA to mono XLR cable build question rockstudio Everything Else 3 18th March 2008 03:21 AM
Summing a stereo signal to mono for bass... MikeHunt79 Subwoofers 1 16th January 2008 09:48 PM
Dual Mono - Anti Mono Power Supplies pmkap Everything Else 3 16th February 2002 05:10 AM
Copyright 1999-2017 diyAudio
