Zapco z400c4-vx problem
Old 28th October 2006, 05:46 AM   #1
shallowfu is offline shallowfu  United States
shallowfu's Avatar
Default Zapco z400c4-vx problem
I have a Zapco z400c4-vx problem.It has no signs of any burned parts and all the mosfets are okay.The protection comes on and i'm thinking it is the outputs.It uses tip35c and tip36c and every sets of those there are tip107 or a tip102 placed.I have never worked on a 4 channel zapco so this layout just doesn't look normal to me and the only other amp i used like this was a soundstream because of its tip102 and tip107 combos.I did notice at the begaining of the row there is 1 tip102 and the other row there is a tip107 that do get hot and protection comes on and they cool and the amp redoes this over and over.
Old 28th October 2006, 06:01 AM   #2
shallowfu's Avatar
Also it seems pin 1 and 3 on tip35c seem to be tied togeather and the same on tip36c.If this is okay let me know because i tryed to trace all the traces and it looks like there are traces in the middle of the board and top and bottom making it very hard to check.
Old 28th October 2006, 07:10 AM   #3
1moreamp is offline 1moreamp  United States
Hey my friend, It could be a four layered card, So your gonna have fun trying to track traces. I worked on 1000 model like this and the fella that owned it had replaced the 120 amps worth of fuses till he burned the internal traces up under the top and bottom layers. ( long brown, expanded areas under the top layer was the give away)
Needless to say he had to purchase a new amp
Hope this helps abit. I have a friend that just rebuilt the Zapco four channel on Amp-guts. I will ask him to respond to your post if he has some time. I think hes a expert now
Have a great weekend
E-mail sent on your behalf to the expert
Old 28th October 2006, 01:39 PM   #4
scott-leanne is offline scott-leanne  United States
Default Zapco Z400C4-SL
Please read my thread all the way through to the end before you replace anything. If it's doing the same thing what mine was doing then this will save you a bunch of time and money.
Even though I should have replaced the NAND gate, doing what I did, worked. Let us know what you find.
Do a search for scott-leanne and read the Zapco Z400C4-SL thread, please.
Scott
Old 28th October 2006, 01:50 PM   #5
On the TIP's, they do get hot, especially the two for the voltage regulation. Thatís normal...
Let us know what you find on the NAND gate..Thanks and good luck.
Scott
Old 28th October 2006, 01:54 PM   #6
I noticed you pulled a semi out. I'll bet it checked good!!
Old 28th October 2006, 05:13 PM   #7
Your in good hands now ! Hope he has your answers. I believe scott-leanne has the best grip on your amp issues
Old 28th October 2006, 06:29 PM   #8
shallowfu's Avatar
Thanks guys!I have ran in new grounds and there are alot of layers but, i will search scott-leanne thread and see what happened.I did take one out because everything i know just confused me after that.I stopped there and thought i would ask for some help.I bought these 2 zapco amp for me and the one is a Z400C4-SL and a Z600C2-SL.They were from the same owner but,i didn't get any info to what happened but, the Z600C2-SL has one tip31c and tip32c fpr regulation and the tip32c was burnt to 3 pins only!I went over that and its working out okay and there was a few things other than that bad.Thanks again for the help.
Old 28th October 2006, 06:54 PM   #9
shallowfu's Avatar
Wow!THANKS SCOTT-LEANNE!Scott-leanne headache sounds word for word what i have.I took a good look at the caps and i would say this could be a great place to start.I will change everything he did and see what happens.I did a search for zapco on the forum but, i never saw the post.justonemoreamp thanks for the heads up on the thread, the hole was getting deep and i didn't think i was getting out!
Old 28th October 2006, 07:05 PM   #10
Cool, Cool, anything for a friend
Zapco z400c4-vx problemHide this!Advertise here!
HELP!! Looking for Zapco oldshoolaudio Car Audio 6 22nd June 2009 09:57 PM
zapco ag 350 genes66 Car Audio 2 28th August 2007 01:31 AM
zapco ag 350 genes66 Car Audio 29 25th August 2007 05:28 AM
Zapco Z400C4-SL scott-leanne Car Audio 23 13th May 2006 07:44 PM
