nte parts - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 20th October 2006, 07:23 PM   #1
Default nte parts
i have a question are nte parts good to use or only use them as a last option my friend that does amp repairs sometimes told me not to use them because 1 nte part cross to like all sorts of stuff like say i have a transitor 3205 and want to use a nte it also says it can be used for irf540 irf 9540 irf1010 just for example so im wondering if nte parts are good or not really considering they cost like twice as much as oem parts
Old 20th October 2006, 07:38 PM   #2
Did it Himself
richie00boy's Avatar
No an NTE transistor cannot be used to replace any IRF parts as they are MOSFETs.
We don't have NTE parts here in the UK but from what I've read on here, they are not great.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 20th October 2006, 11:00 PM   #3
When you repair any device you should know precisely what semiconductor you're installing. With NTE and similar parts, you really don't have a clue what the part is. You have to rely on the judgement of someone who has no clue how the part will be used. This is especially true of discrete parts. For specialized ICs like vertical deflection driver ICs in TVs and such, they may be OK because there is only one IC that will work.
Old 21st October 2006, 06:35 AM   #4
Tried them (NTE) 15 years ago. They were xxxx then and I'm sure they are not any better now.
General replacement parts might work for shade tree repairs, but todays products generally have tighter engineering and that does not leave room for wide range replacement devices. Not if you want product performance to spec.
NTE's hay-day was back when you could not query the net for parts worldwide in less time than it takes to call home.
Use the right parts and relieve yourself of the guess factor that you might have just installed.
Been there, and done that. Never again. Plus they cost more than the correct exact part. Guess it must be all that relabelling they do, along with the single item packaging costs
Please Lord let my painful experiances in my youth become someone elses wisdom A-men !
Old 21st October 2006, 07:21 AM   #5
shallowfu's Avatar
I don't like NTE and they might make every part but, they are one of the highest priced parts out there.Try it stick with the exact part and if you can't find it, ask someone here and we will all help.
Old 21st October 2006, 09:51 AM   #6
Send a message via AIM to DigitalJunkie
When I was fiddling with building an RF amp,I used an NTE transistor I had in my junk..rated at 100W.Everone said not to expect anymore than 75% of it's rating (~75W).
That darn amp never did work right.
So yea,NTE parts apparently aren't 'up-to-spec' either.
Old 21st October 2006, 02:09 PM   #7
Send a message via Yahoo to RetroAudio
I have not had good luck with NTE. What semi's I have seen are pretty pitiful looking when measured. They are supposed to manufacture their own but I think they buy out other company's rejects and package them up. Well, that's what I was reminded of when I looked at the last jfet I got from them. Since then, no more. NTE is Nam Tai Electronics and is traded on the NYSE.
Old 21st October 2006, 10:17 PM   #8
shallowfu's Avatar
I had the same luck with RF amps and NTE.They failed the fastest in using them in RF amps i found.Junk!
Want to trade: PC parts for speaker parts. Spasticteapot Swap Meet 8 15th January 2007 01:02 PM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
Trade your DAC parts for chip amp parts jeff mai Swap Meet 3 12th July 2004 03:51 PM
Comparison of SMD parts to standard parts BrianGT Parts 0 2nd July 2002 09:09 PM
Copyright 1999-2017 diyAudio
