kenwood kac 7202
kenwood kac 7202
Old 17th October 2006, 03:19 PM   #1
mike49504 is offline mike49504  United States
Default kenwood kac 7202
hi im working on a kenwood amp kac 7202 and checked all the outputs the test fine amp turns on but the red light stays on all the time its in protecion mode what do i check next or how do i get it out of protection
Old 17th October 2006, 04:38 PM   #2
sdoom is offline sdoom  Germany
wasn´t kenwood using the green light for ptotection ? I remember on my KAC-823 and KAC-1023 the red light indicated normal operation....
Old 17th October 2006, 05:49 PM   #3
yeah im sorry the red light means its fine but the red light shuts off almost instantly meaning its going into protection wondering what else i check
Old 17th October 2006, 05:54 PM   #4
Are all power transistors in the music-output section ok ? Usually you can test this with an ohmmeter when the amp is off. Check for shorts between the power transistor legs.
Usually there are always two transistors belonging to one channel, one is an NPN , the other the PNP transistor, on both types usually the center leg is the collector. Try to check resistance between the two collectors , if there´s always a short there might be broken power transistors or faulty rectifier diodes in the power supply section.
Also try to check resistance of each collector to speaker GND , again ther e must be no short there.
Old 17th October 2006, 09:43 PM   #5
thanks for your help it had a blown transistor on the left channel replaced it and works fine thanks again
kenwood kac 7202Hide this!Advertise here!
kenwood kac-715 purocolt Car Audio 6 16th May 2014 10:23 PM
Kenwood KAC-X4R matdotcom2000 Car Audio 0 20th December 2007 02:36 PM
Kenwood L-07D... bulgin Analogue Source 0 14th July 2007 07:18 PM
Which dac has this Kenwood? tubee Digital Source 5 22nd August 2006 07:34 PM
PLEASE! Kenwood help! mjarve Solid State 1 23rd September 2004 04:04 AM
