Perry Babin, Can you help me?I need a picture of a 2nd gen 225 orion.I removed mosfets,ref,outputs a long while ago and forgot where they go.I have has this board laying around for awhile.A picture or just placement,Thanks again!
#2 |
http://www.bcot1.com/canons3macro/225/IMG_4062b.jpg
http://www.bcot1.com/canons3macro/225/IMG_4063b.jpg http://www.bcot1.com/canons3macro/225/IMG_4064b.jpg http://www.bcot1.com/canons3macro/225/IMG_4065b.jpg
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Thanks,I had it laying around for awhile and it was stuck in clipped.I replaced everything but, clipped told me maybe replace the op's because thats the only thing i haven't changed.I'm going to put evrything back on and see what happens.Do you have a lj 500.1 insides pictures?Amp guts didn't help.
#4 |
What section?
The smd parts require tight shots to be usable.
#5 |
#6 |
http://www.bcot1.com/canons3macro/jl/IMG_4091b.jpg
http://www.bcot1.com/canons3macro/jl/IMG_4092b.jpg Let me know if you need any others or if these missed the actual components you need.
#7 |
Those were perfect and i picked the board up in ebay.It was all there but, those parts.It looks worth making it a diy project or if i can get a sink.What do you think of it?
#8 |
I think you should get it working before you spend any time looking for a sink.
They're generally easy to repair (because the problems are generally simple). If the board isn't damaged and the output inductor isn't damaged, you should be able to get it going.
#9 |
I have stacks of many brands of boards over the years bought on ebay and other but, the outputs were bad only and i think someone just parted it a little.Thanks to you i will get those parts next time a put a order in and see what happens.If it doesn't work it doesn't matter it was bought for parts anyways.
| Perry or someone please explain | audiobahnkid592 | Car Audio | 17 | 25th February 2008 07:38 AM |
| Mr. Babin and Mr. Bezjak...... | 69CamaroSS396 | Car Audio | 24 | 14th September 2007 09:32 PM |
| Hello from Port Perry | Budsker | Introductions | 4 | 15th February 2007 06:12 PM |
| Page generated in 0.07966 seconds (81.20% PHP - 18.80% MySQL) with 10 queries |
