Go Back   Home > Forums > General Interest > Car Audio
Old 12th October 2006, 12:04 PM   #1
Question low pass filter
Hey guys, I have just entered in this forum and it seems it's great.
Well first of all I had a question about preamp filtering:
I've got a 200w car amplifier(phonocar) briged and a 12" boschman sub. my problem is that my amp has got no preamp filtering. just full pass.Listening to music in that way is terrible, believe me.
I was wandering if I can construct a low pass preamplifier filter which allows frequencies under 80Hz and goes at 18 or 24 db/octave. It doesn't matter to me if it is a passive or active filter.
Old 12th October 2006, 12:09 PM   #2
Did it Himself
richie00boy's Avatar
You need an active filter. Search here and Google for "sallen-key filter" it's pretty easy.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 12th October 2006, 01:46 PM   #3
Yeah it is really simple but I don't understand what kind of operational amplifier should I use. Any identifying code will be a great help.
Here is the link if u need to have a glance
http://www.ecircuitcenter.com/Circui.../opsalkey1.htm
Old 12th October 2006, 02:27 PM   #4
Did it Himself
It's really not that critical TL071 is a good place to start.
Old 13th October 2006, 06:19 AM   #5
OK I will try that. I hope it helps.
I just had a look at the google and there is something i don't understand in that Operational Amplifier. (I might admit it, I am not at all experienced in making up electronic circuits)
What do I connect to
OFFSET N1, OFFSET N2, and NC pins. Well I imagine NC is connected to ground but I can't figure it out what to connect to the other 2 pins.
I really need that help.
If u need to chek that out the link below might be usefull
http://focus.ti.com/lit/ds/symlink/tl071.pdf
Old 13th October 2006, 08:12 AM   #6
Did it Himself
Do NOT connect NC to ground, it's "Not Connected".
Offset 1 and 2 are for nulling out DC offset, leave them unconnected or whatever the manufacturer tells you to do in the data sheet.
Old 13th October 2006, 08:49 AM   #7
Woow what a terrible mistake i have done. . .
I told u that I was unexperienced in circuit building.
Now I see... NC stands for "not connected".
Well does it matter if I don't connect the offset terminals at all. Will it affect the results I expect?
Did I thanked you for the help?I guess i haven't. well, thanks a lot. I really appreciate your advices. I'm glad I am part of this forum now.
Old 17th October 2006, 11:38 AM   #8
Dan2 is offline Dan2  South Africa
don't connect the offset terminals to anything - the opamp is running at unity gain so it won't make a noticable difference
Old 17th October 2006, 11:53 AM   #9
Did it Himself
Just read the datasheet of the op-amp chip you intend to use.
Old 20th October 2006, 09:19 AM   #10
I just made up the low pass circuit based on TL072 op amp. Well let me say that the result was great. but.... after a few minutes working in music a terrible noise came out of the sub and I immediately disconnected the amp from power source. Then I removed the filter and the amp was completely OK. connected again the filter but the noise was again present. I think i have blown up the op amp of the filter cause i supplied it at +18 -18 volts dual voltage of the amplifier. may this have caused the problem? If so then at what voltage should I supply the TL072 op amp? specifications from the producer say from +/-5 to +/-18 volts. can u help me please?
need help with low pass filter prezden Multi-Way 11 12th January 2009 08:04 AM
Low pass filter help ifrythings Subwoofers 1 24th February 2006 09:45 AM
NO low pass filter? jmar Digital Source 7 19th January 2006 12:53 PM
low pass filter crazyant Car Audio 3 15th September 2005 06:15 PM
Page generated in 0.09164 seconds (79.93% PHP - 20.07% MySQL) with 11 queries
