#11 |
http://www.littelfuse.com/data/en/Data_Sheets/466.pdf
This datasheet should apply to that fuse. P = 3A. It should read very near 0 ohms. If it measures higher than 1 ohm, it's defective.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#12 |
Im not sure if my situation is the same as his but i have been using deh-p6500 for many years and it never happen to me before. The other day I install the aux port (ip-bus) to my ipod using RCA. After a few mins, i get an annoying, loud static noise. I switch over to radio and cd player, and i still get that noise. If i turn off the headunit for a few minutes, and turn on again, it doesn't make that noise until 5-10mins later. When i took out my headunit, the back was very hot.. and i try to check it out what making the noise and didn't find anything missing or loose wires.
Could be i have the same problem and i should do the same exact thing?? |
#13 |
Hey Perry, Would this cure a slight alternator whine or no?
#14 |
With most systems, an open shield on the head unit (or on any signal processor in the signal line) will cause significant noise. If the noise is minor, you may be able to reduce it to acceptable levels by reducing the gain on the amp.
#15 |
Hey, great work, just happened to mine, need to repair then will do what you have posted here, do i have to do that with all rca cables?
#16 |
You can generally ground only one to restore the shield ground for all of the RCA outputs. If one or more of the ungrounded channels produces noise, ground them also.
#17 |
The sensitive ground issue is well-known on certain Pioneer head units. See this thread:
http://www.diymobileaudio.com/forum/...0prs+grounding at the diymobileaudio forums for info. It's a very long discussion, but the answers are all there. In a nutshell, there is a TINY fuse or sacrificial resistor that burns out if the grounding is not handled carefully. To prevent problems, DO NOT connect/disconnect any RCAs to anything if the unit is on. In fact, disconnect the 'phantom' power as well. When it comes to installation and such, the first thing to attach is the ground, and the last thing to disconnect is the ground. It was also recommended to ground the chassis to the same point as the harness ground. |
| Grounding problem? | Bas Horneman | Tubes / Valves | 16 | 5th September 2008 04:33 PM |
| Will a CD-I200 IP-Bus adapter work with Pioneer DEH-P860MP? | contentryder | Car Audio | 4 | 5th April 2008 11:15 AM |
| pioneer DEH-P860mp | speye | Car Audio | 1 | 3rd February 2007 11:28 AM |
| Grounding / hum problem with Pioneer table | draven66 | Analogue Source | 1 | 11th November 2005 02:35 PM |
| Grounding problem | LaZarus | Solid State | 8 | 23rd March 2004 01:15 PM |
| Page generated in 0.10296 seconds (74.41% PHP - 25.59% MySQL) with 11 queries |
