rockford fosgate 500s - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 20th October 2006, 03:14 PM   #11
ok the 2a's do check bad but no one around me sells them and i wanna get this amp fixed and outta here my friend said i could replace the 2a's and 1a's with a regular like to-92 case if so do you know what the 2a's dross to and the 1 a's cross to like a a06 or 56 just wondering if u might know that info?? i just was wondering due to the availbility of parts and they are always fun to solder back on
Old 20th October 2006, 03:38 PM   #12
I've soldered them directly to the pads but you have to be very careful. If you apply any pressure to the A06/A56 when soldered to the pads, you risk lifting the pads (very bad). I'd recommend using the correct part.
Now if you insist on doing it the wrong way...
The 1A is roughly equivalent to an A06. The 2A is roughly equivalent to the A56. Look up the datasheets for the transistor:
http://www.fairchildsemi.com/ds/MP/MPSA06.pdf
The pins are marked.
I'd recommend using an adhesive (Goop) to tack the to-92 case transistors to the board. From there, wire the transistor to the board with a small gauge wire. Computer ribbon cable from a 40 conductor IDE cable will work. Don't use a heavy wire. It will break the pads. Secure each wire to the board so no stress is applied to the pads.
This will work fine but if you're getting paid for this job, I'd recommend that you either tell the customer precisely what you've done or order the correct parts. If another tech pulls it apart and sees it, he's going to tell the customer that you did a poor job.
Old 20th October 2006, 04:04 PM   #13
hi im gonna order the right parts for it i soldered in the a56 just to see if the amp would work and it works fine but like u sais im gonna get the right parts for it thanks again
Old 20th October 2006, 04:48 PM   #14
i have a mtx amp im parting out and the transistors are marked 2g and 1gm are theese the same as the 1a and 2 a? just wondering if so im gonna rob the parts to fix the fosgate amp
Old 20th October 2006, 07:04 PM   #15
The 'g' version is the a06/a56 transistor in the sot-23 case. The 'm' is for motorola. It's not necessary to use motorola parts. The 'a' components are mmbt3904/3906 transistors.
The 'g' components are good replacements for the 'a' components but not vice-versa.
About rockford fosgate 1500bd RICKY01AGUAS Car Audio 19 28th June 2009 01:28 AM
rockford fosgate 200x2 spooney Car Audio 7 17th May 2009 09:50 PM
rockford fosgate 1500 bd mike49504 Car Audio 18 30th December 2008 08:37 AM
Rockford Fosgate 325.1 phreaktor Swap Meet 1 29th February 2008 12:54 AM
New Rockford Fosgate amp. $50.00 NerdMike Swap Meet 0 5th March 2005 12:57 AM
Copyright 1999-2017 diyAudio
