any kicker zr experts out there?
Old 30th September 2006, 06:11 PM   #1
marko is offline marko  United Kingdom
Default any kicker zr experts out there?
just playing around with my zr240 and can only get it to work right in bridged mode, it has the swx module fitted (sub module), does this mean it's really a dedicated sub amp? only the right rca input seams to have an effect!! to get any output from the left channel i have to plug the rca into the left rca OUTPUT of the unit, not ideal and not as loud as the right channel....
damn this thing has some power too for 60watt per channel amp though!!
Old 30th September 2006, 07:27 PM   #2
Perry Babin is offline Perry Babin  United States
There could be a number of problems.
The modules were notoriously unreliable and were difficult to repair. To check the function of the amp itself, you can bypass the module by soldering jumpers across the pins shown in the following image. Remove the module when the jumpers are in place.
http://www.bcae1.com/opamptemp/modulejumpers01.jpg
The solder connections at the base of the vertical interconnect board failed commonly.
The front-end op-amp (at the RCA jacks) could be defective. This isn't too common but I've seen it a few times.
The RCA input jack could have broken/weak connections but this is generally seen as an intermittant sort of problem.
Old 30th September 2006, 10:10 PM   #3
thanks for the info, just had another play and the amp works fine when "low passed" but when highpassed only the right channel works correctly! i think it could well be the x-over card...
any kicker zr experts out there?Hide this!Advertise here!
Kicker 600.1 mike49504 Car Audio 3 25th March 2009 05:10 PM
Kicker L5 in a 1.75 box skooter Car Audio 4 16th October 2008 02:54 AM
Kicker L7 skooter Car Audio 5 26th September 2008 12:36 AM
Kicker 500 si stormtrooper Car Audio 0 25th September 2006 02:20 AM
Kicker: KX vs. SX NaftaliG Car Audio 0 11th December 2004 09:21 PM
