where to get sub signal from
Old 24th September 2006, 08:57 PM   #1
terminatorgunit is offline terminatorgunit  United States
Default where to get sub signal from
i have a 1998 Toyota 4Runner Limited edition with the stock head unit in it. and i put a 10 pioneer sub and a 400watt rampage amp in it.
but, i cant figure out where to get the signal for the amp
any sugestions would greatly be appriciated
thanks
Old 25th September 2006, 04:48 AM   #2
xplod1236 is offline xplod1236  United States
xplod1236's Avatar
Send a message via AIM to xplod1236
Take the rear speaker signal (from the rear speakes seems like the most logical idea), run it through a line out converter, and then run the rcas to the amp.
Old 26th September 2006, 06:09 AM   #3
ya but there are no rear speackers al the bass comes from the 4 middle speackers
Old 26th September 2006, 09:42 AM   #4
xplod1236's Avatar
Then get it from there. But if this is the case, I think it might be easiest to tap into the wires behind the head unit.
Old 27th September 2006, 05:44 AM   #5
my amp has a port called hi-input
cant i just take the signal off the middle ones and put it in the high in the amp?
Old 30th September 2006, 09:58 PM   #6
boris333 is offline boris333  Canada
boris333's Avatar
yes, just plug your wires to the high in
where to get sub signal fromHide this!Advertise here!
PWM signal to Audio signal possible? thx_dts71 Class D 2 11th November 2008 02:38 PM
How do I turn an high current signal into a line level signal?? sardonx Tubes / Valves 8 27th August 2005 11:16 AM
int. low signal tenderland Tubes / Valves 3 14th June 2005 01:46 PM
Creating a differential signal from a single-ended signal for bridged amps Peter Daniel Chip Amps 45 8th November 2004 12:47 PM
signal out on a CD ROM RMS Digital Source 5 8th May 2002 08:29 AM
