Hi
I have the Ford stereo with steering wheel controls. is the a good way (without replacing the stereo) to add a amp that goes from speaker level? do the speaker to line level devices work? or should I just leave it alone.
speaker to line level converters or "line out converters" will work but with reduced sound quality because they use cheap transformers. you could also try a balanced line receiver to get the line out.
