Driver recommendations... - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 16th September 2006, 08:16 PM   #1
Default Driver recommendations...
am looking for some high quality car drivers (woofer or could strip down 2 or 3 way) would like a 6X9 or 8 inch round. Looking for an Fs of about 30 Hz and a Qts of 0.6 or higher (higher prefered) and an linear Xmax of 5 or more mm. I am interested in building these into multiple driver ripole cabinets (see link http://www.boxenselbstbau.de/hifi/in...aka_geh_en.htm)
Does a driver like this exist? Are there any cheap car drivers that would do the job? Thanks for you input. Best regards Moray James.
PS thanks for letting me ask as I have zero experience with car audio.
moray james
Old 18th September 2006, 08:30 AM   #2
Lothar34's Avatar
Send a message via AIM to Lothar34
There are a few Goldwood 8" subs that come close to what you want, but none of them match everything you're asking for.
Most car 8" subs are designed to be used in small enclosures and don't have a Qts that high.
Old 19th September 2006, 03:19 AM   #3
Default Thanks....
there are some interesting Goldwood driver at reasonable cost. You are right that the Qts of most 8 inch bass drivers is on the low side since they find thier way into small boxes. 6x9 driver are for the most part ment to be run in a door on on the back deck and so will tend to have higher Qts to help offset low frequency roll off. Ther my be some inexpensive choices there.
As I search I am finding a number of good quality pro drivers in the 12 - 18 inch range. Some of these drivers are not farr off in price (somewhat higher) than using multiple 8 inch drivers factoring in a probable price of 15 -20 dollars each. So given the extra mechanical work with multiple drivers unless some good ones can be had for 10 dollars each the bigger drivers are looking to be more cost/time effective.
Anybody used any really good 6x9's with a cur off od around 40 Hz.? Regards Moray James.
moray james
Old 19th September 2006, 07:16 AM   #4
Lothar34's Avatar
Here you go:
http://www.crutchfield.com/S-6N6uQCJ...=107MM2084#Tab
Not sure what the real going price for those things is. I'd bet you can do better than Crutchfield's price though.
Old 19th September 2006, 07:19 AM   #5
Lothar34's Avatar
Actually, the Vas on those Polks is really low, so they may not work for you either.
I can't find the T/S parameters for these:
http://www.woofersetc.com/index.cfm?...roduct_ID=2591
but I know a guy who's using them as subs with IB in his car and he says they're great. Kicker says they're for free-air use, but they don't list the T/S parameters in the user's manual even.
Sub driver recommendations smallangryboy Subwoofers 0 3rd August 2008 01:11 PM
have enclosure, need driver recommendations talis Subwoofers 6 2nd January 2007 04:08 AM
Driver recommendations The_Mox00 Multi-Way 5 5th September 2006 07:58 PM
12" driver recommendations for TL sub?? jjkozlow Subwoofers 2 21st December 2005 12:17 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 06:54 PM
Copyright 1999-2017 diyAudio
