Help me with simple circuit
Old 22nd August 2006, 07:40 AM   #1
valterdaw is offline valterdaw  United States
Question Help me with simple circuit
I just returned from dead very nice CD/MP3 player. After hooking it up, I noticed that it is not giving +12V output to power antenna/amps, but there is special pin in harness for that. Opened it again and... this pin is not connected to anything .
I found where I can splice to +8V internally (which can be on/off from headunit). I need chematic probably based on FET, or PNP of bulletproof relay (actually, simple relay will work fine, just don't have one that clicks on 8V) to make that +12V output switchable by +8 low power source. That output should sirvive accidental connection with +12 and ground... Thank you!!!
Old 22nd August 2006, 08:09 AM   #2
Perry Babin is offline Perry Babin  United States
This should work. The 4148 can be replaced by virtually any diode. It's not necessary but it protects the input circuit in case the FET shorts. If you want added protection of the drive circuit, insert a 1k ohm resistor in series with the diode.
The 8v will drive the FET on. The FET will ground the relay coil.
Old 22nd August 2006, 08:15 AM   #3
Thanks, Perry! That's exactly what I need
Help me with simple circuitHide this!Advertise here!
Looking for a simple circuit Skitch72 Tubes / Valves 19 12th August 2009 08:31 PM
HELP-- I need a simple 50W AMP circuit --- MTO audio Solid State 5 9th August 2007 07:46 AM
comment on this simple psu circuit jarthel Power Supplies 13 14th August 2006 08:26 AM
Searching for simple circuit gary f Tubes / Valves 8 12th September 2005 04:00 PM
simple circuit for beginner JAZZ2250 Tubes / Valves 4 8th April 2002 02:33 AM
Copyright ©1999-2017 diyAudio
