Preamp Power Supply Suggestions
Old 22nd August 2006, 01:47 AM   #11
anatech is offline anatech  Canada
anatech's Avatar
Hi Tom,
If you generate +- 12 ~ 15 VDC, you can run your circuit off higher rails.
I didn't see your actual preamp circuit.
-Chris
Old 22nd August 2006, 02:32 AM   #12
TomSSS is offline TomSSS  United States
The preamp circuit is actually an attenuation circuit. I just called it a preamp to simplify things. The input signal is AC coupled and and then biased to Vcc/2 using an artificial ground circuit. I've attached a drawing showing the Linear Regulator and the Artificial ground. At the time of the design I was hoping that separating the chassis ground and circuit ground with a 100 ohm resistor would be enough to bring the signal above the noise level.
I've decided to change to the switching power supply. If I do that I can eliminate the Linear Regulator and the artificial earth. I'm hoping in the end the cost to build the switcher will be about the same as the linear IC and artificial ground, and I'll get better results.
Tom
Old 22nd August 2006, 02:37 AM   #13
And the linear power supply with artificial earth
Old 22nd August 2006, 02:43 AM   #14
Perry Babin is offline Perry Babin  United States
That's a lot of work for an attenuator. Why not try a simple potentiometer in the RCA line?
Old 22nd August 2006, 02:52 AM   #15
I agree, it is a lot of work for a simple attenuator. And for most cases a simple mechanical log pot would work great. But, a digital attenuator is being used, so it gets a little bit more complicated.
Old 22nd August 2006, 12:53 PM   #16
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Tom,
That's about it. I agree with Perry that you MUST use a transformer for true ground isolation to get the desired noise reduction.
Try this link at National on Isolated SimpleSwitcher PSUs:
http://www.national.com/an/AN/AN-1095.pdf
and this one on a three-output LM2577-based isolated DC-DC converter.
http://www.national.com/an/AN/AN-777.pdf
In it, the two bipolar voltages are (+/-7.5V). For greater headroom, increase the turns using the calculations there to get (+/-12 to 15V).
Good info there, and I have to imagine theae were done specifically with audio applications in mind.
Old 24th September 2006, 08:57 PM   #17
Thanks for all help. I built a couple of different switchers to test out. The audible noise problem I was having is gone. However, I am seeing 100kHz noise on the primary and secondary side. I will most likely build an LC filter to get rid of this.
Tom
Old 25th September 2006, 03:48 AM   #18
N-Channel's Avatar
Tom,
An L-C filter is a good idea. I would cross-couple the windings of both the (+) and (-) outouts together (opposite phase, of course) to provide for better cross-regulation in the event of sudden input voltage changes or output current demands. This should attenuate the 100kHz switcher noise present to almost undetectable levels. Also, if you pop open your typical AT or ATX PSU, you will fing that the BIG yellow/white multi-winding toroid in the output section does this.
Even better, do this: L-C-L-C for both (+) and (-) buses, where the first Ls are the cross-coupled inductors, and the second Ls are individually wound.
Old 26th September 2006, 04:30 AM   #19
Any recommendations on filter topologies. I only have experience with the cookbook filters (Butter, Cheby, Bessel) and digital filters.
Preamp Power Supply SuggestionsHide this!Advertise here!
LP12 Motor and Power Supply suggestions dsavitsk Analogue Source 7 30th September 2011 01:10 AM
suggestions for new power supply transformer eduard Power Supplies 0 15th June 2008 11:58 AM
Power supply suggestions needed Budric Parts 6 17th February 2008 05:49 AM
LM3886 power supply suggestions? DrFrankenstein Chip Amps 7 7th February 2007 09:16 PM
