Go Back   Home > Forums > General Interest > Car Audio
Old 13th August 2006, 03:10 AM   #1
Default old mtx mta 250 high current problem
First off , I got the amp with a modified speaker out/remote turn on plug.I know I got the remote turn on figured out becuase it turns on and plays through left channel fine.So after trying all combinations of the possible speaker outputs I think that the right side must not be working(even though the clip indicator led's will both light up).Does anybody here have a close up photo of the speaker outs directly from the pcb?If so, can someone give me the polarities and the bridged sum output locations?Also, if indeed the preamp section is getting the signal and the speaker outs are correct, can someone help me solve why there is no output on the right channel?
Old 28th November 2010, 06:11 PM   #2
404Amps is offline 404Amps  United States
404Amps's Avatar
This taken from the OEM label on the bottom of my MTA 2x50. If looking at the top of the amp from left to right ther are 5 leads.
2-channel
1= left pos, green
2= left neg, grn/blk
3= right neg, grey/blk
4= right pos, grey
5= remote turn-on, blue
Bridged
right neg, grey/blk= speaker neg.
left pos, green= speaker positive.
Old 28th November 2010, 06:46 PM   #3
There may be a bad connection between the contacts on the board connector and the wire connector. Try pushing up/down on the connector with speakers connected to see if the audio will play through on the dead channel.
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
high current vs high voltage power Clipped Car Audio 28 19th April 2007 06:06 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
high volt/high current DIY home PS. deepanger Solid State 24 13th December 2002 12:17 AM
BU208a HV/High Current jackinnj Swap Meet 0 28th October 2002 08:48 AM
Page generated in 0.07340 seconds (67.87% PHP - 32.13% MySQL) with 10 queries
