Power Amp limiter
Power Amp limiter
Old 26th July 2006, 05:36 AM   #1
yugaaa is offline yugaaa  India
Send a message via Yahoo to yugaaa
Default Power Amp limiter
I was wondering if anyone has a circuit which can limit the power drawn by the amplifier when the car ignition is switched off .
I use the stock battery which came with the car ,the battery must most probably be a 70Ah one ,though I am not sure about it .
The car is a brand new one ,so I dont want to replace the alternator and and mess up with the warranty .
I had been on a date last week ,and I was doing around 50kms /hr . I had replaced the headlamps to 90/100w and with the amp turned on ,the battery got drained and ,my car had stalled .
It was embarassing for me to ask my girl to push the car to start it .
could anyone help me out with a current limiting circuit for the amp ,so that the amp dosent draw more current than what the amplifier can supply ?
Old 26th July 2006, 09:43 PM   #2
Perry Babin is offline Perry Babin  United States
I don't know what the current capacity of your alternator is but unless you have a VERY powerful amplifier, the battery should not have been drained to the point where the engine stalled. Charge the battery and with the engine running, measure the voltage across the battery terminals. It should be at 13.5 volts or higher.
If the alternator is working properly but simply can not support your audio system, you need to use a second battery and a battery isolator. This will prevent the amplifier from draining the main battery.
Old 27th July 2006, 04:25 AM   #3
perry ,
sorry for being too naive ,but what is a battery isolator ?
I havent heard of any such thing .
Old 27th July 2006, 05:17 AM   #4
http://www.bcae1.com/battiso.htm
You would likely use the first type shown on the page (diode type isolator).
Old 27th July 2006, 02:17 PM   #5
sr20dem0n is offline sr20dem0n  United States
Send a message via AIM to sr20dem0n
It's called the volume control...
A little bit of self control goes a long way
Old 27th July 2006, 10:59 PM   #6
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
I once ran 680W of amps from a 37A alternator..
Never stalled,but man did it make the headlights dim at a stop light..
Once I found out the (puny!) rating of the alternator,out came the amps...
Get your charging system checked out,it seems something isn't quite right...(unless,as already mentioned,you've got massive amplifiers in there,and a stock charging system.)
Old 28th July 2006, 12:42 AM   #7
I'm currently running over 2200w in amps off of the stock 80A alternator with no problems.
My vote is for a bad alternator, you REALLY have to have it cranked (and have massive amps) to run the battery dead with the car on using music, and stall out the car on top of that. Unless you have a 2000rms+ amp and were playing test tones at full volume with the girl in the car, my guess is you have a bad alternator...
Old 28th July 2006, 01:30 AM   #8
Jexx is offline Jexx  United States
Send a message via MSN to Jexx
Ditto to the above post.
In addition, once the battery is drained, it has sustained permanent damage. It will not charge to full capacity...You might need to get that replaced as well...
Old 1st August 2006, 10:37 AM   #9
Thank you guys for the information .
Perry ,thx a lot ,your site was very informative .
Power Amp limiterHide this!Advertise here!
volume limiter please help Dan2 Everything Else 10 4th December 2008 01:44 PM
AGC is used in subwoofer for limiter! GPE Subwoofers 7 7th January 2007 02:29 PM
Do you think this is a limiter? destroyer X Solid State 7 12th December 2004 12:26 AM
Limiter with SA 571 hanzs Solid State 0 4th October 2002 05:46 PM
