I have an Arc 400.4 power amp and I'm going to wire it up on Tuesday. What size fuse should I use on 12V + cable? The amp draws 46A @ 380 watts. Tom Daugherty
#2 |
you could go for a 40A if you're not going to push it hard, if you will, use 50A.
#3 |
Thanks.
#4 |
Are you talking about the fuse by the battery?
It depends on the cable you're using, not the amp. I'm assuming you're using 4awg, if so then any fuse below ~120 amps will work fine. If you're using 8awg then any fuse below ~80 amps will work fine. Those are the upper limits, you want to stay below that and above the amp's normal draw so it doesn't blow under normal circumstances. In your case, above 50 would be fine, however you might as well just fuse at the max your wire will safely support so that you don't have to replace it if you add another amp or replace your current amp sometime in the future. |
| How to find the size on a fuse to "Soundstandard MA3600" ? | k2teknik | Solid State | 5 | 8th May 2009 02:31 PM |
| Fuse housing melting but fuse not blowing, ppi amp | rawadia | Car Audio | 21 | 2nd August 2008 10:39 AM |
| Transformer <-> Fuse size question? | mariusn | Chip Amps | 23 | 24th July 2007 09:30 AM |
| Fuse Size | Adam M. | Chip Amps | 4 | 22nd June 2004 04:17 PM |
| Page generated in 0.28858 seconds (26.29% PHP - 73.71% MySQL) with 10 queries |
