Grounding to battery in high power systems
Old 21st July 2006, 04:40 AM   #1
Jexx is offline Jexx  United States
Send a message via MSN to Jexx
Default Grounding to battery in high power systems
I was reading my owner's manual for my PPI PC2350 and it claims if an amplifier is over 600watts RMS, an additional grounding wire should be run to the negative terminal of the battery to prevent the amp from overheating and/or engine noise problems.
How accurate is that?
Old 21st July 2006, 05:28 AM   #2
Glowbug is offline Glowbug  United States
Glowbug's Avatar
As long as you have a good ground return through the chassis, and have upgraded the battery-to-chassis ground with a larger gauge, you're fine.
If you don't have a lot of metal on the frame, and can't get a good chassis ground - then yes, run a seperate wire back to the negative post.
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 21st July 2006, 05:47 AM   #3
TO-3 is offline TO-3  Peru
TO-3's Avatar
Send a message via Yahoo to TO-3
Default Re: Grounding to battery in high power systems
I always run a return to my battery. Some cars have poorly conduting chassis and end up causing ground-loops. I run a cable from the battery and then ground the chassis at the spot that I ground the amps.
Check out Tube Driver BLUE products at: www.tubedriver.com
Old 21st July 2006, 01:21 PM   #4
vadi is offline vadi  Austria
vadi's Avatar
Default Re: Re: Grounding to battery in high power systems
Hi!
Could you pleas explain that?
I simply grounded both amps via cables to the battery and the HU via chassis. Is that a problem?
Sladjan
Old 21st July 2006, 04:34 PM   #5
TO-3's Avatar
Default Re: Re: Re: Grounding to battery in high power systems
Originally posted by vadi
Hi!
Sladjan
I run a ground from my battery to the chassis at the point where I ground all of my electronics. I used to have a Saturn that had a body with high resistance. I later found that the body is spot welded together and at those points the resistance is increased which will cause a ground-loop. I figured why not ground each panel to the battery? The metal frame still has a good ground but adding a solid retun is the best way to ensure that the ground has minimum resistance.
Old 22nd July 2006, 05:41 PM   #6
vadi's Avatar
Thanks!
Grounding to battery in high power systemsHide this!Advertise here!
Battery Based High-End DA Converter. yangsmm Vendor's Bazaar 14 21st August 2008 01:24 PM
calculating total power in PA systems Disney_SK Solid State 11 16th June 2005 11:46 AM
Battery powered gainclone grounding? abkingsbury Chip Amps 0 10th August 2004 05:51 AM
Wiring high Watt sub woofers into home audio systems. Broken_Sight Digital Source 1 8th January 2004 12:28 AM
Copyright ©1999-2017 diyAudio
