Go Back   Home > Forums > General Interest > Car Audio
Old 20th July 2006, 03:51 PM   #1
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Default Tubes as preamp..
Any one done anything with ECC86 or Ecc88/6DJ8 for car use,preamp or anything else fun?
Regards Åke
Old 24th July 2006, 10:56 AM   #2
rt7085 is offline rt7085  United States
Default Vibration....
I would not recommend using tubes in a car as vibration is a tubes greatest enemy. This will break. Also, if you want to use them, you may need a step-up supply as they run on voltages much higher than the battery supply in a car environment.
Never give up and play fair.
Old 24th July 2006, 05:36 PM   #3
TO-3 is offline TO-3  Peru
TO-3's Avatar
Send a message via Yahoo to TO-3
Default Re: Vibration....
I had a tube system in my car for over 6 years (4 12AX7s and 4 5881GC's) with absolutely no problems. Tubes have been used in rugged applications for quite a long time with a good track record. Soon enough I shall be putting another tube system in my car.
Check out Tube Driver BLUE products at: www.tubedriver.com
Old 24th July 2006, 06:29 PM   #4
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, Ryssen,
You can try this, ECC88 (or 6DJ8), supply voltage is only +/-24V (You'll need to build an SMPS, though, but not a lethal voltage one )
Old 24th July 2006, 09:57 PM   #5
Ryssen's Avatar
Some guys at headwize was using ECC86 and an inverter to get +- 12v,maybe that could be sommething?
Regards Åke
Old 25th July 2006, 02:03 AM   #6
lumanauw's Avatar
+/-24V is still to high? How about this one, only 12V, the tubes you can use anything, 12AX7, 12AY7, 12AU7, ECC88, any triode you have can work, in this low voltage, because it is connected as "common grid"
Old 25th July 2006, 12:53 PM   #7
Ryssen's Avatar
Are you using the cathode as a grid?
Regards Åke
Old 25th July 2006, 02:13 PM   #8
lumanauw's Avatar
Cathode=signal input, anode via 100k+transistor=output, grid to ground via 1k.
Old 25th July 2006, 05:09 PM   #9
Ryssen's Avatar
What transistor are beeing used,just any ordinary or?
Regards Åke
Old 25th July 2006, 05:34 PM   #10
lumanauw's Avatar
Anything in your hand will work, but gain like BC550 or BC560 better
Building a preamp - somewhat new to tubes jscherer Tubes / Valves 3 19th February 2009 03:21 AM
Zen V8-like Preamp using Tubes needtubes Pass Labs 1 18th August 2006 07:25 AM
preamp tubes change mongiak Tubes / Valves 3 19th August 2005 05:44 PM
J-FET preamp/DI vs tubes qveda Solid State 2 30th December 2004 05:05 AM
What tubes are best for preamp? ronjg Tubes / Valves 7 31st May 2002 11:36 AM
Copyright ©1999-2013 diyAudio
