Go Back   Home > Forums > General Interest > Car Audio
Old 18th July 2006, 04:58 PM   #1
Question What is your choice of power supply/output FET's
To be on a safe side, it's always great to put a new part, with same label as old one, but it's not always possible and there are better parts on market these days. What is your choice of FET's: power supply and outputs? Especially TO-220AB ones.
I am using IRF540, IRF9540 as outputs, and HUF75339P3 for power supply. Seems to be working everywhere. Got an idea from MTX
Old 18th July 2006, 05:01 PM   #2
jackinnj's Avatar
some like the IRFP240 + IRFP9610 combination
Old 18th July 2006, 06:43 PM   #3
Power supply:
For amps using IRFZ34 and IRFZ46 I use IRFZ44N. The Z46 is rated for slightly more current but has a significantly higher Rdson so the Z44s are likely to run cooler. I've never had a failure of the Z44s when used in place of the Z46s.
For amps using higher current FETs and low value gate resistors (less than ~50 ohms), I use IRF3205s.
For fully encapsulated FETs (like those used in Japanese amps), I use IRFIZ44.
For outputs in relatively new amplifiers, it is generally difficult to improve on the original. The manufacturers often use the highest rated (current rating) for the rail voltage used in the amplifier. For older amplifiers, you may be able to find a better substitute because the technology has advanced from the time that the amp was manufactured.
Old 18th July 2006, 09:58 PM   #4
Send a message via Yahoo to RetroAudio
working on older gear is a great way to bone up on components and their characteristics, what to look for and such. A great learning tool and it's surprising what pops out at you and what you learn.
Old 19th July 2006, 05:38 AM   #5
N-Channel's Avatar
Send a message via AIM to N-Channel
Power Supply = MTP75N06 Rds(on) = 9mW
Outputs = IRFP240/9240
Old 19th July 2006, 07:54 AM   #6
ifrythings's Avatar
Power supply: IRF3205 55V 75A Rsd(on) 6.5m Ohm
And for output, same as N-Channel.
Old 22nd July 2006, 03:55 PM   #7
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
seems like the IRF3205 is the crowd favorite. same here. the car amps I make always use that.
I haven't changed output devices in amps yet.
Old 23rd July 2006, 11:10 PM   #8
IRF2804S-7P Rds=1.6mOhm. Makes the fullbridge a viable topology for 12V powered supplies.
http://www.irf.com/product-info/data...rf2804s-7p.pdf
Here's a new P-CH I found.
http://www.ixys.com/98769.pdf
I have not tried it yet, but with twice the current rating of an IRFP9240, it's worth a look.
Is it the good choice - power supply johnny52 Solid State 3 10th January 2008 12:22 AM
Choice of Power Supply Caps kptseng Power Supplies 7 16th March 2006 03:45 PM
power output higher than power supply...How? loonatron Analogue Source 9 24th March 2005 08:04 PM
Sonic Impact power supply: another choice FORMD Class D 0 6th February 2005 04:57 PM
tailor output voltage of power supply Evaas Solid State 15 28th April 2001 07:55 PM
Page generated in 0.09811 seconds (79.21% PHP - 20.79% MySQL) with 10 queries
