Sony MDX-C6500R radio problem - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 18th July 2006, 10:15 AM   #1
Bgt is offline Bgt  Netherlands
Default Sony MDX-C6500R radio problem
When the unit plays for some time, especially on a hot day, the radio sound goes completely bananas. Any id what this could be? Looked inside and measured the voltage rails but did not find anything weird. The MD section works ok most of the times but I remember it having gone nuts also sometimes.
Does anybody have a schematic/diagramm of this unit?
Kind regards,
Bert
Old 18th July 2006, 12:38 PM   #2
jmateus is offline jmateus  United States
jmateus's Avatar
Default Sony radio
Hi Bgt
I don't know if this applies to your problem but your'e not too specific about the problem with the radio going "bananas".
The fact is I had a problem with mine when I first installed in
the car, it would cut off intermitently.
Took to the Sony service center (twice) and nothing happened
the problem would subsist, until I decide to fix it myself even though at the service center they "replaced" an IC "that was
causing the problem".
To make the story shorter, after resoldering the board and
checking the obvious, I finally found the problem, it was a
speaker terminal touching the ground of the car intermitently.
A simple problem that could have been resolved in a snap and
took a couple of months.
Moral of this story, check the obvious, make sure that speaker wires are well dressed and not touching anything, grounding
problems are the worse to find.
Good luck
JLH 2005, Cyrus and so on...
Old 18th July 2006, 08:24 PM   #3
what I meant with the tuner going bananas is that the sound get very distorted like a station which is not properly tuned. On cold days this does not happen that often. What could this be?
Kind regards,
Bert
Old 18th July 2006, 08:32 PM   #4
es44 is offline es44  Denmark
es44's Avatar
I can't tell you what the problem is, but if you have an e-mail address with room for approx 5Mb, then at least i can help you with a complete service-manual.
Old 18th July 2006, 08:36 PM   #5
jmateus's Avatar
It seems to be a heat related problem. Does it play ok CD (or cassette)? If it does the problem is only in the tuner, this way you
can isolate the malfunction to the tuner (or not).
Some IC that's getting hot scrambles the tuning all together.
Sincerely I would take to a Sony service center, even though I always have problems with them, no matter what. But at least
they know (or should) their own stuff.
Good luck
Old 20th July 2006, 07:46 PM   #6
Good luck
The MD's play ok most of the times.
Kind regards,
Bert
Old 21st July 2006, 11:56 PM   #7
docfin is offline docfin  Europe
Account Disabled
Service manuals for Sony MDX-C6500 available here
3 different manuals, covered models with indexes R, RX, RV, X (i.e. 6500R etc.)
Old 22nd July 2006, 09:51 AM   #8
es44's Avatar
Why pay for manuals, when there are nice people here: Sharefx
radio problem jeesus Solid State 1 1st August 2008 11:00 AM
Problem with Panasonic CQ-C5300N Car Radio JoergST Car Audio 4 13th April 2008 07:59 PM
Radio problem on noninverted GC??? 5150ed Chip Amps 2 17th August 2006 03:25 PM
Sony Sports Radio - How to.... peranders Everything Else 4 9th April 2006 10:51 AM
Sony XM Radio Sawzall Digital Source 2 3rd January 2002 05:46 PM
Copyright 1999-2017 diyAudio
