Need Help by alpine 3566
Old 15th July 2006, 02:16 PM   #1
JoergST is offline JoergST  Germany
Send a message via ICQ to JoergST
Default Need Help by alpine 3566
Hello everybody, I have a problem with a alpine 3566. It is a 6 chanel amplifier with 4 normal chanel and 2 sub chanel. In the beginning the 2 sub chanel are defekt.
In the power supply there are some 2SD1669 defect and some 1 and 10 Ohm resistors. In the output stage there was a 2SC4387 defect.I change the 2SC4387 with a BD 249C and the 2SA 1672 wih a BD 250C.
Now the problem: If I switch one the amplifier the current rise up to nearly 3 Ampere, and one of the two trafos make a strange noise. If I unsolder the rectifiers in the alpine, the current goes to nearly 2 Amperes and the trafos make no crazy noise. If the rectifiers also connected the current rise up and the noise is back. I have unsolder the transistors from the output stage, but the error is still there.
Have someone an idea or something like that?
Regards Jörg
Old 15th July 2006, 05:50 PM   #2
Perry Babin is offline Perry Babin  United States
Do the power supply transistors you replaced get warmer than the ones in the other supply when the amp is making the strange noise?
If you have a scope... While it's making noise, look at the collector waveform on both power supplies to see if there is a difference. Also compare the power supply base waveforms.
Do the outputs in the sub channels get hot/warm?
Is there any noise on the sub channel output?
According to the service manual, idle current is 3.5 amps.
Old 16th July 2006, 09:41 AM   #3
Talking Alpine 3566 little success
Hello Perry,
I have some little success :-)
There was a solder joint after I have after-soldered the small Transsitors in the output stage.
The amplifier works now, but I didn“t get a noise out at the speaker terminal.
The current is 3.69 A.
But I have an other problem.
One of the µPC 1270 get very, very hot. It is the IC 606. The IC is in one sub canel. Over 70° and higher. The other µPC1270 are worm not hot. So what can I do?
I download a PDF diagramm from this IC.
Pin 1 und 2 get +28Volt and PIN 9 and 10 get – 28Volt.
Sorry I haven“t got a oscilloscop
Regards Jörg
Old 16th July 2006, 01:05 PM   #4
If you can't find any defective components between the driver IC and the outputs, I'd suggest swapping the two ICs in the sub channels. If the same IC gets hot when it's in the other channel, the IC is likely defective. If the If the other IC gets hot when it's in the channel that was causing the other IC to overheat, you need to find the problem with the components around the IC.
As a side note, those ICs typically have a lot of failing connections. I'd suggest that you resolder all of the connections on all of the driver ICs in all channels.
Old 16th July 2006, 01:30 PM   #5
Default Alpine 3566
I make a measurment in the two sub channel. In every sub channel there is a µPC 1270.
So I measure the voltage at every PIN.
The good IC:
Pin 1-2: 28 Volt
Pin 3: 22Volt
Pin 4-5: nothing
Pin 6: -26,6 Volt
Pin 7: -1,2 Volt
Pin 8: + 0,5 Volt
Pin 9 -10: -28 Volt
Pin 11 -12: 0 Volt
Mysterios IC
Pin 1-2: 28 Volt
Pin 3: 22Volt
Pin 4-5: nothing
Pin 6-12: -26,6 Volt
Is the IC defekt?
I am afraid to change the IC because I will not destroy more in the amplifier when the IC is defect.
Regards Jörg
Old 16th July 2006, 01:53 PM   #6
Those readings are confusing because with all of the negative drive, the output should be near the negative rail but it doesn't seem to be because the feedback to pin 5 is at zero volts.
Is there any DC voltage on the speaker output terminals of the sub channels of the amp?
Post the voltages for the outputs of the sub channel with the overheating IC.
NPN base:
NPN collector:
NPN emitter:
PNP base:
PNP collector:
PNP emitter:
You said the amp was working. Are you getting any sound out of the two sub channels? If so, does it sound distorted?
Old 16th July 2006, 06:50 PM   #7
Default Measurment
Hello I made a measurement.
I built in the sub channel BD 249C PNP and BD 250C NPN transistors.
Here are the result
Good Sub Chanel
BD 250C PNP
Basis - 586mV
Kollektor - 28V
Emitter - 5,6mV
BD249C NPN
Basis 527mV
Kollektor +28V
Emitter 0,3mV
Bad chanel with overheating IC
BD 250C PNP
Basis -364mV
Kollektor -28V
Emitter 0V
BD249C
Basis 247mV
Kollektor + 28V
Emitter 0V
I measure the DC Voltage on the chanel. I hope I did it right.
Chanel 6: 11mv
Chanel 5: -12,6mV
chanel 4: 15mV
Chanel 3: -15mV
chanel 2: 15mV
chanel 1: -15mV
Regards Jörg
Old 16th July 2006, 07:07 PM   #8
There is either a problem with the voltage measurements or you have open resistors (5.6 ohms) between the driver IC and the outputs.
Old 16th July 2006, 07:43 PM   #9
Default Measurment alpine 3566
I don“t think so, that there is either a problem with the voltage measurements. I think I have made a correct measurement.
I connected the minus holding wire from the measuring instrument to the minus pol of the boxen terminal at the amplifire.
It was the minuspol from chanel 6.
The plus holding wire from the measuring instrument I put it on the transistors BD 250 and BD 249 Emitter, Kollektor and Base.
I really wonder why the measurment result are so differnet, but this is what I measure.
The resistors for the transistor are 5,6Ohm. That is the value which stands in the connection diagramm for the resistors.
I think the IC 606 is damaged. I will buy a new one and than we will see what happen.
Regards Jörg
Old 16th July 2006, 07:58 PM   #10
In one post, you stated that the voltage on pins 6-12 was -26.6 volts. In another post, you stated that the base voltages of the same channel were less than ±1 volt. There's no way for the 5.6 ohm resistor to survive the 25+ volts across it. This means that one set of measurements was incorrect.
You could be correct. The IC could be defective but I hate to see someone replace a component unless it's actually defective.
Need Help by alpine 3566Hide this!Advertise here!
is this an alpine amp? jol50 Car Audio 30 29th April 2008 03:11 AM
Alpine F#1 Status audioplus Multi-Way 0 23rd December 2007 01:06 AM
Alpine 3566 rookie9713 Car Audio 1 18th October 2006 11:03 PM
Need Connection diagram for Alpine 3566 JoergST Car Audio 3 7th July 2006 09:10 AM
PPI vs. Alpine smokeaway Solid State 2 28th August 2005 10:51 AM
Copyright ©1999-2017 diyAudio
