help me i was hookin up the rmt and the screwdriver stuck to the body an it just quit
Old 8th July 2006, 09:04 PM   #1
razordave123 is offline razordave123  United States
Send a message via AIM to razordave123
Default help me i was hookin up the rmt and the screwdriver stuck to the body an it just quit
I had my jensen xa 3022lx hooked up and workin fine till my uncle told me i should bridge it well we didnt know what we were doin so that could also have caused it but i think it was when my rmt grounded off of the body with my screwdriver any help is welcome thanx
Old 8th July 2006, 09:08 PM   #2
also any kind of schem or other help on what to test and how to test it would be nice thank you also i have a fluke tester so i should be able to test most if u explain
Old 8th July 2006, 09:15 PM   #3
heres some pics
http://community.webshots.com/photo/...85802711SFowbT
http://community.webshots.com/photo/...85802711HtajmG
Old 8th July 2006, 10:20 PM   #4
Perry Babin is offline Perry Babin  United States
It's possible that the amp failed but it's more likely that the head unit has a blown fuse in the remote lead or has been damaged and will need repair.
Check the remote output from the head unit. Set the Fluke meter to DC volts. Turn the head unit on. Connect the black meter lead to a known good ground. Connect the red lead to the remote lead from the head unit. You should read ~12 volts with the head unit on and zero volts with the head unit off. If you have ~0 volts when the head unit is on, pull the head unit to see if the remote has an inline fuse.
Old 8th July 2006, 10:22 PM   #5
thanks for the advice but i just ran a toggle switch to the rmt because the head unit is stock so there is no power antenna or such
Old 8th July 2006, 11:11 PM   #6
If this was properly installed, there should have been a fuse in the line feeding the toggle switch.
Before you can do anything else, you need to confirm that the remote has voltage.
You should also confirm that the B+ line has 12v.
Old 9th July 2006, 02:09 AM   #7
yep both have 12v
Old 13th July 2006, 04:33 PM   #8
NOT THE PROBLEM
Old 19th July 2009, 05:00 PM   #9
caveman420 is offline caveman420  United States
Default resistor
can you tell me the value or a closeup of the side of this resistor
http://thumb7.webshots.net/t/75/75/2...7OMJqni_th.jpg
help me i was hookin up the rmt and the screwdriver stuck to the body an it just quitHide this!Advertise here!
Please Recommend a Torque Screwdriver Seraph Everything Else 12 17th August 2008 01:42 PM
LEDs in amps quit jol50 Car Audio 1 27th November 2007 04:39 AM
Insulated screwdriver for RF coil tuning jackinnj Everything Else 0 4th November 2005 04:14 PM
What if you want to quit? Bill Fitzpatrick Everything Else 6 23rd July 2002 02:11 AM
