1) Will bridging an amp to 2 Ohm and using 2 4 Ohm subs in parallel be better (ie. louder or harder hitting) than running it at 4 Ohm stereo with said subs wired in stereo?
2) I'm really wanting to start my own car audio store where I live. How in the heck do you find REAL wholesale places and not those claiming to be wholesale and just selling at regular retail prices? Any help with either will be greatly appreciated.
THERE ARE NO STUPID QUESTIONS.... ONLY STUPID PEOPLE |
#2 |
1) If the amp can drive 2ohm bridged (most can't, some can drive 2 ohm per channel stereo = 4ohm bridged, to drive 2 ohm bridged the amp would need to be able to drive 1 ohm per channel stereo) yes, you'll get loads more power. /sreten.
#3 |
there is a switch on the amp. one position is 4 Ohm the other is labled "2 Ohm (bridged)"....i'm guessing that is what it means
it's an older model pioneer amp and i've searched their site for a users manual but no luck thanx for the info
#4 |
The amp will likely only be able to drive 2 ohm stereo or do 4 ohms bridged. As sreten said, bridging into 4 ohms means each amp sees a 2 ohm load, which is why 2 ohm operation is labeled for bridging (into 4 ohms). Bridging into 2 ohms will most likely lead to a dead (or cutting out) amplifier if pushed too hard.
| Quick SMD resistor questions | spooney | Car Audio | 3 | 30th January 2008 01:30 AM |
| 2 quick SI questions | Decker | Class D | 2 | 26th November 2007 11:30 PM |
| Few Really Quick Pass Amp Questions | JPeitzman | Pass Labs | 30 | 17th September 2007 08:54 PM |
| 2 quick questions | JPeitzman | Chip Amps | 7 | 22nd July 2007 05:27 PM |
| quick questions | theChris | Multi-Way | 0 | 12th February 2003 04:54 AM |
| Page generated in 0.07468 seconds (71.74% PHP - 28.26% MySQL) with 10 queries |
