What are these SMD drivers - UY 013, WY 017
VRT ECA 2005
Hello I have looked into the ECA VRT 2005 list and find some things.Perhaps it could help you :)
The UY 013 is a ZUMT 848 B and the WY 017 is a 2 SC 3915
I put you a picture from the ECA VRT 2005 Disk to this thread.
regards Jörg
If the attached image is what you have, the following may work:
2sd1898 NPN, 80v, 1a
2sb1260 PNP, -80v, -1a
On a JL amp I have here it appears that the WY is the PNP but due to other parallel components, I couldn't confirm that with 100% certainty. Verify this on your amp.
