Go Back   Home > Forums > General Interest > Car Audio
Old 5th July 2006, 04:59 PM   #1
Question Will 1/10W SMD's work as gate drive resistors?
20 ohm, and they are smaller then original toasted ones (due to FET's failure) Probably it is bad idea.
Old 5th July 2006, 07:49 PM   #2
If you're doing this repair on your own personal amp, the 0805 sized resistors would likely be OK (if they are long enough to make contact with the solder pads).
If this is an amp that you're repairing for someone else and you're charging them for the repair, order the correct part. If the customer takes it to another shop and they see that someone has used the wrong size component, they're likely to tell the customer and that's likely to tarnish your reputation (even though the smaller part is large enough to do the job).
Old 5th July 2006, 08:09 PM   #3
Thank you! Good to know. This is a beer-charge amp
Gate Drive Transformer microsim444 Everything Else 1 2nd December 2008 12:52 PM
Isolated gate drive IC is finally HERE!! rtarbell Parts 0 16th September 2008 06:31 AM
ucd gate drive, discrete or integrated? zilog Class D 14 4th February 2006 06:23 PM
Gate drive transformers? Loial Power Supplies 3 18th October 2005 09:17 AM
Page generated in 0.06629 seconds (69.98% PHP - 30.02% MySQL) with 10 queries
